Hotchkis SFC's and CalTracs are in! - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 24th, 10, 04:10 PM Thread Starter
Tom P's Avatar
I had every intention of doing this install myself - glad I didn't
Both the Hotchkis SFC and CalTracs work great together. The SFC's are nice and tight to the floor boards and well designed. I went with the low profile CalTrac front mount - it ends up being 1/2" higher than horizontal.
A few tips for anyone else -
Install the CalTracs first so you can center the rear notch in the SFC to provide access to the front mount.
The lower shock/CalTrac mount needed to be drilled out to match the Hotchkis U-Bolts. I am sure the mount was drilled for stock u-bolts.
You'll need a press to push in the alum bushing into the front spring eye. Also slid a piece of 3/4" dia. heater hose over the Caltrac roll pin to prevent chatter.
The other trick was getting the old rubber subframe body mount out and the new urethane mount in before you weld in the SFC. Start to finish, including welding, touch up, etc was about 12 hours
The car now feels tight and solid on rough roads and sticks in the turns without twisting. Can't wait to put these to the test with upcoming 496.
ID:	16933   Click image for larger version
ID:	16934   Click image for larger version
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #2 of 6 (permalink) Old Jul 24th, 10, 04:40 PM
Skip
Skeeter55's Avatar
Re: Hotchkis SFC's and CalTracs are in!
Looks good Tom and great advice for others...
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 6 (permalink) Old Jul 24th, 10, 04:48 PM Thread Starter
Tom P's Avatar
Thanks Skip, tips from your install helped alot
Tom P is offline
post #4 of 6 (permalink) Old Jul 29th, 10, 08:20 AM
Nevin
Sweet!!! Is there any way you can post a pic or two from about 10' away from the car so I can see how low everything hangs? Thanks
Check out my body work thread here...
I know I know it's slow going. But I, like most don't have enough time. lol
NOR_CAL_67rs is offline
post #5 of 6 (permalink) Old Jul 29th, 10, 03:36 PM Thread Starter
Tom P's Avatar
not great pics, but you can get the idea.
the critical ground clearance on my '69 is the scattershield and Hooker collectors
5-1/2" clearance from ground to the bottom of the sub-frame
5-1/4" clearance from ground to low point on Hotchkis SFC
4-3/4" clearance from ground to low point on CalTrac low profile mount
ID:	17065   Click image for larger version
Tom P is offline
post #6 of 6 (permalink) Old Jul 29th, 10, 06:12 PM
Rod
Nice! Reminds me I need to install my Cal-Trac bars that have been sitting on a shelf for over 4 years now....
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
