8.5 x 10 rear - mono to multi - Team Camaro Tech
post #1 of 13 (permalink) Old Jul 24th, 10, 07:34 PM Thread Starter
Hey all,
I've got a stock 10 bolt/mono coming out of my 68 and will be putting in a 8.5 10 bolt from a 74 nova. Since the pearches are set for the multi's, can I just bolt in multi's or do I have to get anything else. I've read where shocks etc don't quite jive. I'd eventually have the car set lower but can deal with it sitting normal for now...I don't want the back end jacked up.
Thanks a bunch in advance...I searched a little but didn't find my info when the different rear end was included.
68 396 (408), M21 4 spd, 8.5 10"
A man with a gun is a citizen - a man without a gun is a victim.
Roses are red violets are blue
I'm schizophrenic and so am I.
1968 Camaros is offline
post #2 of 13 (permalink) Old Jul 24th, 10, 07:42 PM
Re: 8.5 x 10 rear - mono to multi
So do you still have the mono leafs in the car or do you have multi leafs in there now?
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #3 of 13 (permalink) Old Jul 24th, 10, 07:55 PM
You can basically do one of two things:
1. Install new multileafs but use the shock anchor plates and shocks from your monoleaf setup. You may find that you need to oval the holes the u-bolts/t-bolts go through (you probably have four t-bolts if your 8.2 is original, but it is best to install at least one u-bolt; the factory performance applications used a u-bolt on the outboard position and t-bolts on the inboard side, but a lot of us use two u-bolts instead for more strength), because the 8.5 holes may be spaced slightly differently. If you reuse the mono anchor plates and shocks, you may find that the shocks do not have enough travel with the new springs (the shocks may be close to full extension with the car just sitting on the springs). Some folks that reuse the mono parts have to add shock extenders (a specialized fastener that adds an inch or more to the top of the shock, fairly inexpensive, $10 or so).
2. Get multileaf anchor plates and multileaf shocks. This is the "right" way to do it, but costs more.
Eric
Eric Kammerer is offline
post #4 of 13 (permalink) Old Jul 25th, 10, 07:43 AM Thread Starter
Everything is tore apart right now so I can go any direction needed.
post #5 of 13 (permalink) Old Jul 25th, 10, 07:44 AM Thread Starter
Eric,
Thanks a million; I'll spend a little more to do it right then!
post #6 of 13 (permalink) Old Jul 25th, 10, 07:56 AM
Ya, I would get your lowering springs, now, if its in the budget. I have an 8.5 in my 67 with hotchkis springs. You will likely need to shorten the drive shaft about an inch or so, depending on which yoke is on the 8.5. I had to enlarge the U-bolt holes on the spring perches because, as mentioned above, they just a tad off from the shock plate holes. I used hotchkis springs & U-bolts. The hotchkis U bolts are much larger diameter then stock U/Tbolts. Scott
69 RS LS3/T56
67 RS LS2/T56
Z06vette is offline
post #7 of 13 (permalink) Old Jul 25th, 10, 09:01 AM
Chris
Scott, I put a new multi-leaf rear in my 68 as well. I got new multi-leaf spring plates, but never put them on. I used traction bars that have shock mounts built in.
I had drilled the new plates out to accept 1/2" u-bolts.
If you decide to use new plates, let me know. You can have them.
68RS Project - taking much longer than expected
FFRiccio is offline
post #8 of 13 (permalink) Old Jul 25th, 10, 11:09 PM
Pete
I went from mono to Hotchkis multi on my 68 Camaro but had to add lowering blocks too cause it was not low enough. So now i have a gap between the brackets that hold the leaf in. Its temporary tho as Ill have to upgrade the leafs to a DSE 3" drop once I have an engine that makes some power. Im also in the process of building an 8.5 so Im curious to see how it goes, post up some pics if you have time. : )
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
post #9 of 13 (permalink) Old Jul 27th, 10, 05:21 PM Thread Starter
Thanks for all the info guys. When things start happening again with it I'll post a few pics. In the process of switching to a different custom shop right now. I'll vent about that in another section of the forums. Thanks again, Scott
post #10 of 13 (permalink) Old Aug 4th, 10, 10:04 PM
Rob
Hope you don't mind if I chime in with a question. I am in exactly (almost) the same place with a '74 Nova 8.5 multi I am putting in my 68 mono with the Hotchkis springs.
Scott, did you use the multileaf shock anchor plates or re-use mono plates?
If you used the multileaf, do you have a recommended source?
I hear some of the repop plates have the ears bent at the wrong angle...or something...
Again, sorry for crashing the thread but it hit home.
Rob
Robster is offline
post #11 of 13 (permalink) Old Aug 4th, 10, 11:55 PM
DSE multi plates are killer quality, fit perfectly and the same price as the repros.
BPOS is offline
post #12 of 13 (permalink) Old Aug 5th, 10, 10:59 AM
Will regular shocks work with the DSE multi-plates on a mono to multi conversion or does it require special shocks of some sort?
67 Convertible, LS1, T56
rockportag03 is offline
post #13 of 13 (permalink) Old Aug 5th, 10, 11:42 AM
I reused the mono-leaf shock plates. I wasnt sure if I went to multi leaf plates, that I would be able to orient them to work with the non-staggered shock setup in my 67. I used the hotchkis leafs, and everything fit pretty well. I had mono springs in my car as well. I will post a pic this weekend if it will help. Other than having to shorten the drive shaft & enlarge the U-bolt holes, it was fairly straight forward. Scott
69 RS LS3/T56
67 RS LS2/T56
Z06vette is offline
