Global west Arms - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 29th, 10, 10:58 AM Thread Starter
Spenser
Global west Arms
I was wondering if the bottom arms are needed?..i would like to put in adjustable coil overs and wasnt sure if the bottom arms do much besides look different.
thanks
Famous68
Famous68 is offline
post #2 of 6 (permalink) Old Aug 2nd, 10, 03:36 PM
Re: Global west Arms
If you are doing the QA1 coil over conversion I'd say it would be a damn good idea. The factory lower control arms were never designed to support the entire weight on 2 tiny shock bolts. At least the GW lowers are beefed up in that area and can hold the load.
Tyler
Teetoe_Jones is offline
post #3 of 6 (permalink) Old Aug 2nd, 10, 04:13 PM
most of the stress is on the upper control arm. the tubular lower control arm really does nothing advantageous. whereas with the tubular upper you gain more caster (less bump steer)
i wouldnt waste your money on the lower. other will probably agree with me.
m21man is offline
post #4 of 6 (permalink) Old Aug 2nd, 10, 04:29 PM
Frank
We sell and install the QA1 and the Global West, among other brands of arms. I have been running those coil over conversions in my street drag car since the late nineties, and I wheelie that car almost every launch. With that said, it sure would not hurt anything to have a beefed up arm, but as mentioned there is no geometry advantage.
ProdigyCustoms is offline
post #5 of 6 (permalink) Old Aug 2nd, 10, 08:33 PM
something like this is a much cheaper alternative in my opinion, unless you think you'll be changing your ride height frequently. Used in conjunction with short circle track springs, from which there is a huge selection, can use stock lower arm, and shock of your choice.
http://www.speedwaymotors.com/AFCO-A...cer,23948.html
http://www.speedwaymotors.com/Adjust...hims,3389.html
http://www.speedwaymotors.com/AFCO-5...ngs,23682.html
BPOS is offline
post #6 of 6 (permalink) Old Aug 4th, 10, 09:13 PM
David Pozzi
davidpozzi's Avatar
The second adjuster listed is too small to fit a shock inside it safely.
davidpozzi is offline
