new leaf springs - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 31st, 10, 02:24 AM Thread Starter
wayne
new leaf springs
so i have a question, I done a lot of search just no answer yet. After install will the leaf springs settle a little or is what i see i get?
wayne33 is offline
post #2 of 12 (permalink) Old Jul 31st, 10, 02:33 AM
Steiner
Re: new leaf springs
Yeah, they'll settle out some. I'd say at least an inch maybe more.
New
Months later
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 12 (permalink) Old Jul 31st, 10, 11:26 AM Thread Starter
wayne
thanks for the answer and pix Steiner
wayne33 is offline
post #4 of 12 (permalink) Old Jul 31st, 10, 04:47 PM
Ted
What leafs are you using (how many)? Did you torque things down after it settled on the ground?
tgifford5 is offline
post #5 of 12 (permalink) Old Jul 31st, 10, 04:54 PM
Bill
Did you leave the bolts loose until it was on the ground, then tighten? That's the right way, and it will make a difference.
'69 375/396 TR 711 71 06A X22D80
LeMans Blue
'55 Chev PU Napco (Original)
350 Bright Yellow
braber427 is offline
post #6 of 12 (permalink) Old Jul 31st, 10, 06:01 PM
Banned
Bethanne
Nashville Beth's Avatar
New
Months later
First time I've seen your car Steiner. NICE !!
Nashville Beth is offline
post #7 of 12 (permalink) Old Jul 31st, 10, 06:32 PM
Steiner
Hey, thanks. I told someone the other day it looks good from fifty feet but you can smell it from a hundred, know what I mean? ROT-ten with a capital ROT.
Ted, I don't know if you were asking Wayne or me but mine are the reproduction four leafs and everything was done correctly. Bouncy, bouncy, bouncy, tighten, tighten, tighten.
Just went out and shot another one so you can see the difference a little more clearly.
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 12 (permalink) Old Aug 1st, 10, 12:41 AM Thread Starter
wayne
mine are 3 leaf jcw. I didnt tighting all the way when off ground, but i did tighten them a little.
wayne33 is offline
post #9 of 12 (permalink) Old Aug 1st, 10, 05:52 AM
Bruce
I have the same issue with "factory 5 leaf" springs. It has been sitting for a year and still loose and drove it 500 feet with a settling in a year it dropped 1/2 inch with a drivers side lean of 3/4 inch. Everything is new, body bushings etc. The wheel well to floor on mine is 27 inches with 235-50-15 tires. I am thinking of putting the old springs in!!!
The Camaro Guy is offline
post #10 of 12 (permalink) Old Aug 1st, 10, 06:16 AM
Lonnie
Lonnie P's Avatar
Just got mine in yesterday & it sits high... not happy wth it.
I was expecting an inch or 2 higher at the most, but not 4".
Afterall the paint work, plus getting everything together without scratches, I'm not thrilled about taking it back apart to get them re-arched.
Lonnie P is offline
post #11 of 12 (permalink) Old Aug 1st, 10, 12:35 PM
DT
Donny
DT's Avatar
Which springs did you use?? It seems the inexpensive repro springs make the car sit too high!
DT is offline
post #12 of 12 (permalink) Old Aug 1st, 10, 07:29 PM
Lonnie
Lonnie P's Avatar
5 leaf units from Camaro's & Classics.
I have 4" above the tire to wheel opening with a 26" tire (68 Camaro)
rear of rocker at crease is 11.5" off ground
Anyone else have measurements?
Lonnie P is offline
