Brake Release..... Won't Release - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 7th, 10, 08:16 PM Thread Starter
Kalif Johnson
Send a message via AIM to dreamweaver
69 Camaro
The parking brake release rod is stuck... I believe in the "open" position, eg; I think it is pulled all the way out.
I can depress the parking brake, and I can release it manually with the lever on top of the mechanism. I haven't pulled it out, but I sprayed a bunch of greased lightning all up inside the mechanism but it won't budge. There's a bit of surface rust all over the parking brake mechanism, but it sets and releases (manually) just fine, I think something might be rusted shut, but I'm not sure what to look for. There's not a lot of room to look inside to see how it works unless I pull it.
Any tricks of the trade?
Anyone got a pic of how the catch / spring mechanism works?
Thanks in advance.
"The masses have never thirsted after truth. They turn aside from evidence that is not to their taste, preferring to deify error, if error seduce them. Whoever can supply them with illusions is easily their master; whoever attempts to destroy their illusions is always their victim." - Gustave Le Bon
dreamweaver is offline
post #2 of 7 (permalink) Old Aug 8th, 10, 01:10 AM
parkbrau's Avatar
Re: Brake Release..... Won't Release
Surface rust is normal for the mechanism. Might not be your mechanism, are you sure your rear brake shoes are not locked down?
parkbrau is offline
post #3 of 7 (permalink) Old Aug 8th, 10, 04:18 AM
Simplicistic design with a single pivot point. You can see the pivot retaining rivot stud head at the front. Return spring is behind the mechanism plate. Never saw one frozen. I have extras. The unit comes out easily, repair should present no problems.
Sauron67MM is online now
post #4 of 7 (permalink) Old Aug 8th, 10, 06:21 AM
ZZ_430's Avatar
Check your cables (3) under the car for being stuck..
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #5 of 7 (permalink) Old Aug 8th, 10, 06:31 AM
ALso check the calipers in oder to make sure that all are working well, if the aforementioned doesn't pan out.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #6 of 7 (permalink) Old Aug 8th, 10, 07:38 AM
prostreet69camaro's Avatar
Jack up the back of the car and see if you can turn the rear tires.
Is it drum brakes or disc brakes??
prostreet69camaro is offline
post #7 of 7 (permalink) Old Aug 8th, 10, 08:53 AM Thread Starter
Kalif Johnson
No, not locked down
Yes - saw the retaining rivet when I was playing with it last night. Sprayed it pretty good, no progress.
All new cables, but I'll check anyway. The parking brake sets and releases (manually) just fine... it's just the release mechanism / rod under the dash that is stuck.
I'm pretty sure the brakes are working fine... but I'll check them anyway.
capt
Yes, I can turn them
Rear drum, front Disc, Original SS with nothing changed except wearable parts
All brake components are new... pads, shoes, calipers, etc. Had the drums turned... all have less than 3,000 miles on them.
