e brake question - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 17th, 10, 06:41 AM Thread Starter
Eli
e brake question
I put the wilwood rear kit on my 67 and bought the lokar kit to finish the e brake. My question is do i need to set the car on the ground before i cut my cables to compensate for suspension travel? I dont want to cut them to short and the first time i hit a bump have the cable get tight. Also i have read on the forum about some people routing the passenger side cable over the axle? Is that a better way to run the cable so i can remove the factory center section? Any help would be great. Thanks
Eli's67 is offline
post #2 of 2 (permalink) Old Aug 17th, 10, 01:06 PM
Re: e brake question
I would at least get the suspension level , as it would be on the ground. The car on jack stands could help.
Won't the stock mid equalizer loop help here?
TC # 349
zdld17 is offline
Tags
e brake, wilwood
