"Lakewoods with a downward trend" - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 18th, 10, 07:22 PM Thread Starter
Gene
When I installed a set of Lakewood Traction bars on my 68 they are lower in the front. The instructions stated that they should not be installed that way. The car originally had mono spring I think since the shock mounts were for a single spring. Sometime, someone added the multi leaf spings. I am wondering if the springs are weak or if I did something wrong in installing the bars. I had jackstands under the rear axle when I tightened everything up. The rubber bumpers are touching the springs, one is in the first hole and the other in the second hole.
Comments would be appreciated.
gene68ss
Also, how do you check springs to see if they are out of spec?
gene68ss is offline
post #2 of 2 (permalink) Old Aug 19th, 10, 05:14 AM
Glenn
Re: "Lakewoods with a downward trend"
You can install wedge spacers between the traction bars and the spring mounts to level them out--I believe Summit still sells them. Also, for street driving, the rubber bumpers should have a gap between the front of the leaf springs. Hope this helps.
lowbuck69x11 is offline
