I need an exploded view of front drum brake spindle bearings assembly - Team Camaro Tech
post #1 of 13 (permalink) Old Aug 21st, 10, 05:50 PM Thread Starter
Michael4yah's Avatar
1
Michael4yah is offline
post #2 of 13 (permalink) Old Aug 21st, 10, 05:53 PM Thread Starter
Re: I need an exploded view of front drum brake spindle bearings assem
Sorry, its a 1968 Camaro RSSS 396 with drum brakes.
post #3 of 13 (permalink) Old Aug 22nd, 10, 08:45 AM
Jeff
yellow69RS's Avatar
from the spindle to the cap ... Seal, large bearing, small bearing, washer, nut, cotter pin, cap.
Jeff
yellow69RS is offline
post #4 of 13 (permalink) Old Aug 22nd, 10, 11:28 AM Thread Starter
Thanks, Jeff. I already assembled it but would like to have it for my records. I havnt had to work on drum brakes in 30 years. If anyone has a diagram of all the drum brake parts and their location Id really appreciate it. Thanks again. Michael
post #5 of 13 (permalink) Old Aug 22nd, 10, 11:41 AM
http://1967-81camarocarparts.com/cat...5%20brakes.pdf
Page 5-11 is the shoes/springs/ect for front drums.
68 Camaro~LSx ~all motor
post #6 of 13 (permalink) Old Aug 22nd, 10, 12:31 PM
Smile Re: I need an exploded view of front drum brake spindle bearings assem
TJS69 is offline
post #7 of 13 (permalink) Old Aug 22nd, 10, 01:33 PM
The pictures are in the service manual, or all kind of cheep of cheep books, the the books for these cars are worth there weight in gold,
Must be nice to just push a button, insted of flippin a page, I never had
that. Buy a set of books, then feel free to ask all the ??? you want.
john68 is offline
post #8 of 13 (permalink) Old Aug 22nd, 10, 02:14 PM
Steps
Real critacal.....how did your tighten up the crown nut?
Do it wrong and the bearings will rumble in a few days/weeks do it right and they will last 100,000 miles plus.
Steptoe is offline
post #9 of 13 (permalink) Old Aug 22nd, 10, 02:18 PM Thread Starter
John, Tom,Doug, Thanks, I have two Camaro books but neither get into the spindle bearing brakes components deal. The 1968 Factory Assembly Instruction manual isnt detailed enough, theres lots of threads on disc brakes but not too many on the details of drum brakes.
post #10 of 13 (permalink) Old Aug 22nd, 10, 02:26 PM
Sorry, Michael, There are 3 other books, Chassis Service Manual, That has beakes, Chassis Overhaul Manual, That tells how to repair, the trans, rear end, after the first book told you how to get it on the bench. The last book is the Fisher Body Manual,
it has doors tin, Everyone needs all 4 Books.
john68 is offline
post #11 of 13 (permalink) Old Aug 22nd, 10, 08:31 PM Thread Starter
Steptoe, Just tightened enough to hold in place. No engine or trans yet. What is the normal torque on a spindle nut?
post #12 of 13 (permalink) Old Aug 22nd, 10, 09:45 PM
Steps
OK i have seen so many times bearing screwed up
Tighten the crown up till quite firm...this makes sure the bearings and stuff are seated.
Back off till loose...then tighen up...usually hand tight till everything is firm...then BACK OFF to the nearest spilt pin hole.
The only time one tightens is if there is the slightest nick to drop the split pin in ..and I mean slightest....
Over tighten destorys bearing fast.
The other thing is packing grease...there are special packers on can buy that keep your hand reasonble dirty (there is an old thread on the subject)...work fine..but hey whats the difference between a little grease on the hands and a heap...
Anyway put a dob of grease on the heal of you hand then wipe the edge of the bearing in it to force in...go around one edge , give a spin, then the other edge...that is usually enough but I always do both edges 2x.
Steptoe is offline
post #13 of 13 (permalink) Old Aug 23rd, 10, 06:33 AM
Michael
Does anybody have a set of drum hubs they can spare?
mahunt is offline
Tags
assembly, bearings, exploded view, front drum
