67 Camaro convertible mono leaf springs - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 29th, 10, 04:51 AM Thread Starter
Sean
I have a chance to purchase a pair of mono leaf springs off a 1967 Camaro coupe. I'm wanting to put these on my 67 convertible. My question is are the coupe springs going to be too weak or saggy for my convertible? What if they were re-arched? has anyone out there used coupe springs on a convertible, if so did they work?
Thanks,
Sean
1967 CAMARO SS/RS 350
4 SPD CONVERTIBLE
TRIPLE BLACK
SSMUNDY is offline
post #2 of 4 (permalink) Old Aug 29th, 10, 07:10 AM
Re: 67 Camaro convertible mono leaf springs
I wouldn't bother with any used ones. New ones are cheap enough.
IIRC, the convertible monos are a little stiffer? Maybe somebody else can confirm. Too bad you weren't closer, i'd give you my used monos. I installed JC Whitney 3 leafs and never looked back.
Melrose RS is offline
post #3 of 4 (permalink) Old Aug 29th, 10, 09:05 PM
JAY
I had 5 leaf springs made at my local spring shop 15 years ago..threw away the mono's Jay
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #4 of 4 (permalink) Old Sep 2nd, 10, 09:08 AM
Kevin
KevinW's Avatar
I measured the new monos from eaton for verts and they are the same thickness as coupes. I re-arched some original coupe monos for my vert (1.5" over stock vert height) and they worked great! Of course, the shop doing the work has to know what they are doing
Kevin
KevinW is offline
