Anyone convert 3rd gen axle studs to 7/16? - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 1st, 10, 02:34 PM Thread Starter
Jeff
Has anyone switched the studs on a 3rd gen Borg Warner axle ( 12mm) to the 7/16 -20 studs? I haven't been able to find a 7/16 stud at the auto parts stores that has the correct knurl size which seems to be about 12.5mm. The 7/16 stud knurl is too small ( about .472, or <12mm). I am resisting drilling to 1/2 since I have a new front disk kit with the 7/16-20s.
Any help is appreciated.
Thanks,
Jeff
ZZ4X4 is offline
post #2 of 8 (permalink) Old Sep 3rd, 10, 08:33 PM
Lee
Re: Anyone convert 3rd gen axle studs to 7/16?
Have you tried Summit, Jegs, or a local speed shop?
69Project is offline
post #3 of 8 (permalink) Old Sep 4th, 10, 08:39 PM
Robert
Get yourself a Dorman catalogue and look up the various sizes. There's 610-175 that has a knurl diameter of .512" and is 1 3/16 long with a shoulder of 13/32". You have to consider a few factors when replaceing studs, knurl diameter, stud length, shoulder height for a good fit. There are a couple other part numbers that look like they might be a good fit.
HOWEVER....why are you changing them? Just to have them match the front? That's silly, so what if your front and rear lug nuts are different (7/16' vs 12mm) they don't need to interchange..they stay at the proper wheel..front vs rear.
1stGenLvr is offline
post #4 of 8 (permalink) Old Sep 6th, 10, 02:41 PM
what was the knurl size of the 78-80 A and G bodies that still had 7/16" studs?
you don't plan sincerity.
novaderrik is offline
post #5 of 8 (permalink) Old Sep 7th, 10, 06:57 AM Thread Starter
Jeff
Looks like the fronts for the A / G body have a knurl diameter of .564 and the rears are .472 according to Dorman. The 610-175 as mentioned by 1stGenLvr looks like the closest match with a .512 knurl ( I need a .501). I may try one to see what happens. The problems with the 610-175 are that the shoulder height is greater and the overall length is shorter. I also checked Summit, Jegs, ARP etc. I assumed this would be a straightfoward conversion! I may need to stay with mismatched studs. :-(
ZZ4X4 is offline
post #6 of 8 (permalink) Old Sep 7th, 10, 10:57 AM
Rich
just wondering why you would want to go smaller studs? what is this B/W 9 bolt in or going into?
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #7 of 8 (permalink) Old Sep 7th, 10, 11:10 AM Thread Starter
Jeff
69 Camaro. The 9 bolt BW was installed by the previous owner and is an IROK-Z G92 Posi. We'll see how it holds up. Although I realize we're talking about a non-stock rear, I still feel like it should be blended seamlessly into original car. I'm not liking the idea of mismatched lug nuts. Seems a little hodge-podge... I don't mind having the slightly smaller 7/16 studs. One other option is to convert the front 7/16s from the CPP Big Brake Kit to 12mm though...
ZZ4X4 is offline
post #8 of 8 (permalink) Old Sep 8th, 10, 08:59 AM
Greg
Symmetry.
I have that same gene, I understand and get it.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
