1969 Camaro mono to multi leaf conversion - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 2nd, 10, 06:37 AM Thread Starter
Probationer
Bret
Has anyone made this conversion and if so what items do I need and where did you purchase them. I have talked to a couple different places and get a couple different answers. I have seen the Hotchki kits and the lower it 1 1/2" or so. Has anyone used the kit that lowers? Did you like it?
I just want to make sure i get it right when I make the conversion and I have everything I need when I start the project.
Thanks for your help.
Bamava is offline
post #2 of 2 (permalink) Old Oct 2nd, 10, 07:15 AM
Skip
Skeeter55's Avatar
Re: 1969 Camaro mono to multi leaf conversion
Yes i have the 1 1/2 lowering Hotchkis multi leaf kit with all the hardware and love it. I cant remember if it came with the new 6-bolts and clips though. You will have to drill a bigger hole in the perch for the new u-bolt size. One more thing before you torque the leaf bolts have the car set on the ground and bounds it up and down before you torque down the leaf bolts.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
