need just a little help. - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 13th, 11, 11:22 AM Thread Starter
Ok I am going to do a standard disc brake conversion from either SSBC or Right stuff and I thought I had all the info I needed and the guy at right stuff asks me if I have a drum brake wheel. I currently have factory drum brakes behind Weld Wheels Pro Stars 14x7 with a 3.75 offset wheel will either of there kits fit behind my wheels? Can somebody tell me what I should be measuring to find out?
Jake
69 camaro 502 TH400 Dana 60 4:10 gears. Old drag car now my little learning lab. Short video of my last time to the track, who knows how many for the car!
Amsoilguy is offline
post #2 of 6 (permalink) Old Oct 13th, 11, 11:40 AM
Send a message via AIM to cuz13
Re: need just a little help.
When I converted to disc I had to get rid of the ol 14's and change to 15's. The 14" rubbed
cuz13 is offline
post #3 of 6 (permalink) Old Oct 13th, 11, 12:13 PM
Kevin
SixtyAte's Avatar
Disk brake kits require the use of 15" wheels. There are some kits for 14" wheels but they are rare and expensive. See link below...
Kev
http://www.ebay.com/itm/64-74-GM-14-...867#vi-content
1964 - 1972 GM A Body Models (see list below)
1967 - 1969 GM F Body Models (see list below)
1968 - 1974 GM X Body Models (see list below)
14" Wheel Front Drum to Disc Brake Conversion Kit
Description
Brand New Front Drum to Disc Brake Conversion Kit
For use on models with Factory 14" Wheels with Drum Brakes
This kit uses your existing Stock O.E. Drum Brake Spindles without modifications.
"The Right Stuff Detailing" Brand Product!!
We are confident that you will like this product that we even list the manufacturers name! Others Don't!!
Complete Disc Brake Power Booster Kit with a Lifetime Warranty
Free Disc Pad Replacement For Life
Manufacturers 800 Toll Free Tech Support Line to assist you with any installation questions
Complete Installation Instructions
All NEW Components - Not Re-manufactured
Kit Includes:
New Proprietary 10" Rotors
Calipers (New)
New Proprietary Caliper Mounting Brackets - Cadmium Plated
Organic Pads
Bearings
Grease Seals
Dust Caps
Castle Nuts
Washers
Cotter Pins
Flex Hoses
Flex Hose Clips
Banjo Bolts
Master Cylinder
Combination Valve
Valve Bracket
Valve Hardware
Brake Switch Pigtail
Pedal Rod Extension
5 Power Booster Assemblies to choose from - see selection below **
Fits The Following A Body Models:
1964 - 1972 Special / Skylark / GS
1964 - 1972 LeMans / Tempest / GTO
1964 - 1972 F85 / Cutlass / 442
1964 - 1972 Malibu / Chevelle / SS
1964 - 1972 El Camino
1971 - 1972 GMC Sprint
1970 - 1972 Monte Carlo
Fits The Following F Body Models:
1967 - 1969 Camaro / Z28
1967 - 1969 Firebird / Trans Am
Fits The Following X Body Models:
1968 - 1974 Chevy II / Nova
1973 - 1974 Apollo
1973 - 1974 Omega
1971 - 1974 Ventura
SixtyAte is offline
post #4 of 6 (permalink) Old Oct 13th, 11, 12:19 PM
I think Matts classic bow ties is having a sale I got my brakes from him, plus lots more good people to deal with
cuz13 is offline
post #5 of 6 (permalink) Old Oct 13th, 11, 03:03 PM Thread Starter
post #6 of 6 (permalink) Old Oct 13th, 11, 04:22 PM
Kevin
SixtyAte's Avatar
SixtyAte is offline
