Too much positive camber - Team Camaro Tech
post #1 of 11 (permalink) Old Oct 14th, 11, 04:36 PM Thread Starter
Jerry R.
jr68's Avatar
After installing my Hotchkiss 2" lowering springs I noticed my wheels have about a quarter inch of positive camber when I measured it across the edge of the rim. I don't know how many degrees that amounts to but it sure looks like too much. Can I take out a shim and get it to move back in ? or isn't it that simple.
ps. I did a search but can't find anything specific enough.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #2 of 11 (permalink) Old Oct 14th, 11, 05:03 PM
Re: Too much positive camber
Any time you do front end work...it's a good idea to get an alignment
68 Camaro~LSx ~all motor
post #3 of 11 (permalink) Old Oct 14th, 11, 05:29 PM
DjD
DjD's Avatar
Doug's correct, swapping front springs = next stop the alignment shop!
...Dennis
DjD is offline
post #4 of 11 (permalink) Old Oct 15th, 11, 07:31 AM
Jeff
yellow69RS's Avatar
If weight is on wheels and the top of the tire is out, you need to add shims to reduce positive camber.add shims to both bolts to maintain caster ad to rear only to increase postive caster. There's not a really easy way to measure caster in your drive way without a guage and raduis plates. You can check camber with a carpenters level, you're looking to be plumb.
Jeff
yellow69RS is offline
post #5 of 11 (permalink) Old Oct 15th, 11, 08:37 AM
Aaron
BigDawgDavao's Avatar
Jerry,
My '67 did exactly the same when I changed springs. A lot more shims needed to be added compared to the old springs. I don't know exactly how many yet cause I ran out of shims before I go it set.
BigDawgDavao is offline
post #6 of 11 (permalink) Old Oct 16th, 11, 11:10 AM Thread Starter
Jerry R.
jr68's Avatar
Originally Posted by BigDawgDavao View Post
Jerry,
Maybe this would be a good time for new control arms , I wonder if the tubular ones are designed to compensate for this or will they have to be shimmed way out too.
jr68 is offline
post #7 of 11 (permalink) Old Oct 16th, 11, 05:58 PM
If you just let it down off of the floor jack it'll have a ton of pos camber because the suspension droops - you need to drive it around the block or roll it back and forth a few times.
BPOS is offline
post #8 of 11 (permalink) Old Oct 16th, 11, 08:44 PM Thread Starter
Jerry R.
jr68's Avatar
Its been 2 weeks and about 100 miles.
jr68 is offline
post #9 of 11 (permalink) Old Oct 18th, 11, 09:43 AM
Hotchkis
Jerry – As the others have pointed out, after installing coil springs you should definitely get your Camaro re-aligned. Installing new tubular control arms before getting an alignment is a good way to save the cost of getting it aligned after installing them. Installing our tubular control arms would reduce shims for caster adjustment but they don’t negate the need for an alignment or having to shim them out to compensate for positive camber.
Thanks for installing our springs on your ’68!
Hotchkis is offline
post #10 of 11 (permalink) Old Oct 18th, 11, 10:16 AM Thread Starter
Jerry R.
jr68's Avatar
You're welcome. I'm very happy with these springs it rides nice and not stiff at all. I notice some handling improvement as well. I was worried they would cause me to bottom out and flatten my headers but the opposite is true in fact I haven't bottomed out yet like I did with my worn out original coils.
jr68 is offline
post #11 of 11 (permalink) Old Oct 19th, 11, 10:09 AM
Hotchkis
Jerry – That’s cool! Worn out original springs are amazingly ineffective and that’s move obvious when headers are involved.
Hotchkis is offline
