Does Gulstrand mod lower the front of car? - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 6th, 11, 08:47 AM Thread Starter
Dustin
I have a 67 with hotchkis 1.5in lowering springs on front and rear. Car is tore down and I am going to do the steering box mod and was considering this also. Just want thw front tires a little closer to the fender w/o a bunch of money. Will this mod actually drop the front end a littlt as well as tightening things up?
1967 RS Convertible, 454, M20 4-speed
dboz67rs is offline
post #2 of 4 (permalink) Old Nov 6th, 11, 08:52 AM
Re: does gulstrand mod lower the front of car?
I never thought about this, but I don't think so. The front end height is mostly determined by the compressed spring length - nothing in the GMod affects that because the spring is constrained by the LCA and the spring pocket in the frame.
The Gmod will give you the ability to get more caster, and that in turn may produce some rubbing when you hit a bump while turning if you run big front tires.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #3 of 4 (permalink) Old Nov 6th, 11, 10:28 AM
Originally Posted by mkelcy View Post
i never thought about this, but i don't think so. The front end height is mostly determined by the compressed spring length - nothing in the gmod affects that because the spring is constrained by the lca and the spring pocket in the frame.
The gmod will give you the ability to get more caster, and that in turn may produce some rubbing when you hit a bump while turning if you run big front tires.
x 2
68 Camaro~LSx ~all motor
post #4 of 4 (permalink) Old Nov 6th, 11, 10:59 AM Thread Starter
Dustin
That's what I figured. Thanks for your help.
dboz67rs is offline
