Freakin Rotors wont go back on!!! - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 8th, 11, 06:54 AM Thread Starter
Ok,
So the outer wheel bearing on my 68 camaro was obliterated.. I took the rotor off and the inner wheel bearing was stuck to the spindle but still in very good shape.. I used a gear puller to remove it and it came off fairly easy.. Then I took the rotor removed the races and installed new races and new bearings (inner and outer) and a new grease seal. I cleaned and inspected the spindle and it looked fine BUT now I am trying to put the rotor back onto the spindle and it will NOT slide all the way onto the spindle!!
My question is how EASY should it slide on? I am assuming it should not be pressed on but I dont want to force it on either.. Is it time for a new spindle or do I need to emery cloth it down? Literally sitting with dirty hands here so anyone that can answer this for me as quickly as possible would be appreciated.
BTW Matched up the size of the inner wheel bearing to the old one and it is the same..Also, the races are fully installed
TOOFUN
mark67ss is offline
post #2 of 7 (permalink) Old Nov 8th, 11, 06:58 AM
Chad
67 Plum's Avatar
Re: Freakin Rotors wont go back on!!!
Polish the spindle with emory cloth.It doesn't take much to keep a bearing from going on.
67 Plum is offline
post #3 of 7 (permalink) Old Nov 8th, 11, 07:21 AM
prostreet69camaro's Avatar
Yes polish it with some emery cloth and lubricate with WD 40.
prostreet69camaro is offline
post #4 of 7 (permalink) Old Nov 8th, 11, 09:03 AM
Kevin
KevinW's Avatar
As Mike and Chad said, all's it takes is one little burr to keep it from sliding on if the race is slanted or too much grease might cause some binding too. You should have tried the race on the spindle before installing in disc, but thats water over the bridge now.
Kevin
KevinW is offline
post #5 of 7 (permalink) Old Nov 8th, 11, 01:17 PM
results?
1969 Chevrolet Camaro 396 SS X-66
1967 Chevrolet Camaro RS Convertible
Brandan is offline
post #6 of 7 (permalink) Old Nov 9th, 11, 05:09 AM Thread Starter
Thanks everyone.. I guess you cant go by what you see and feel.. Couple of passes with some emery cloth and it slide right on perfectly!!
mark67ss is offline
post #7 of 7 (permalink) Old Nov 9th, 11, 06:09 AM
Paul
Thumbs up Re: Freakin Rotors wont go back on!!!
Cool!! Great to hear that shes going back together!!
1969 RS/SS DROPTOP is online now
