Air Shocks- Are these original? - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 17th, 11, 01:18 PM Thread Starter
PA Camaro Guy's Avatar
My '69 has a pair of air shocks in the rear that can be adjusted via a tire-valve stem that comes through the rear bumper. This is located underneath the pumper in the proximity to the license plate.
Are these shocks original? The reason I ask is that I don't see replacements listed for them on Year One or Classic Industries. They're kinda cool and I wouldn't mind replacing with the same, but mine tend to bleed out air after a while and need a recharge frequently.
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
post #2 of 10 (permalink) Old Nov 17th, 11, 02:10 PM
Bobby
Re: Air Shocks- Are these original?
If you like them, spray the shock body, line and valve with soapy water and see if you can find the leak. It might be as simple as a leaky schrader valve or the line to the shock.
Even if the leak is in the body internally it can probably be rebuilt.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #3 of 10 (permalink) Old Nov 17th, 11, 02:36 PM
DjD
DjD's Avatar
No 1st gen came from the factory with air shocks... The only reason you might want them is if you tow behind your car. They do nothing to improve ride or handling.
...Dennis
DjD is offline
post #4 of 10 (permalink) Old Nov 17th, 11, 03:11 PM
DT
Donny
DT's Avatar
X2. I would add that guys used air shocks to compensate for sagging springs.
DT is offline
post #5 of 10 (permalink) Old Nov 17th, 11, 04:45 PM
Harry
My car had been raced and had air shocks to give the fat tires clearance. The upper mounts were screwed into the sheet metal behind the rear seat!
Beemervet is offline
post #6 of 10 (permalink) Old Nov 17th, 11, 05:18 PM
If the shocks are white, Gabriel HighJackers, 125 lbs max.
If they are yellow, Monroe Lifts, 125 lbs max.
If they are aqua or torquise, Delco Pleasurlifts, 90 lbs max.
Twenty-five lbs min for all.
As said, not OE.
post #7 of 10 (permalink) Old Nov 18th, 11, 08:52 AM Thread Starter
Thanks all for the ideas. This is making some sense to me. My car has traction bars (old ones) installed on multi leaf springs which came with the 350 option on my car. (Original motor long since gone, replaced with an 80's 350 block, which I took out and replaced with 383)
Could be that the traction bars required the rear end height to rise and so the air adjust shocks were used. Shocks are white.
Hopefully in December I'll be doing my rear end swap, so I'll be taking them out and I'll see what condition they are in, and if anything on them is serviceable.
1969 Camaro 383
post #8 of 10 (permalink) Old Nov 18th, 11, 08:58 AM
Air shocks could have been used to lift up the body so rear tires would not rub on the wheel opening, as compared to '67 & '68.
post #9 of 10 (permalink) Old Nov 18th, 11, 09:16 AM Thread Starter
That's horrible! I can one up you though. When I bough this car almost 20 years ago, it was on its way to being raced. Headers don't fit with the AC "suitcase" on the firewall... solution? Torch that out of the way. Yeah.
1969 Camaro 383
post #10 of 10 (permalink) Old Nov 18th, 11, 01:06 PM
Michael
Doug Thorley tri-y headers work with small block AC applications.
mahunt is offline
Tags
air shocks
