69 Disc Spindle - Which is R or L - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 21st, 11, 02:25 PM Thread Starter
Clint
I took my disc brake spindles off my 69 to detail them and now I got them mixed up. How do you tell the right from left? I can't find a part number on them and they look exactly the same. All the catalogs show right & left spindles so there must be a difference.
Thanks for any help.
cwb90
cwb90 is offline
post #2 of 7 (permalink) Old Nov 21st, 11, 04:23 PM
prostreet69camaro's Avatar
Re: 69 Disc Spindle - Which is R or L
The spindles are the same. Doesnt matter which side you use them on.
prostreet69camaro is offline
post #3 of 7 (permalink) Old Nov 21st, 11, 05:31 PM
T
Ja -- 67-69 camaro stock spindles are the same L to R and have bolt-on steering arms. Most aftermarket lowering spindles (as well as the 2nd gen spindles) have the steering arms cast-in, so there's a L and R side on them...
TMessick is offline
post #4 of 7 (permalink) Old Nov 21st, 11, 06:03 PM Thread Starter
Clint
Thanks to the both of you for the reply. This would have drove me crazy. I wonder why the catalogs list them as seperate.
Thanks again,
Clint
cwb90 is offline
post #5 of 7 (permalink) Old Nov 25th, 11, 09:19 AM
The reason they list them different is because there is a difference between a drum brake spindle and a disc brake spindle.
post #6 of 7 (permalink) Old Nov 29th, 11, 07:52 PM
David Pozzi
davidpozzi's Avatar
If they are assembled with calipers & steering arms, a "Knuckle Assembly" the caliper & steering arm goes to the rear.
davidpozzi is offline
post #7 of 7 (permalink) Old Nov 29th, 11, 08:42 PM
and that difference is only how far they machine the upper boss down.
you don't plan sincerity.
novaderrik is offline
