Leaking power steering Box - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 25th, 11, 01:01 PM Thread Starter
steve
I have a 81 Z28 with a leaking power steering control box I assume. I assume the best is to purchase a rebuilt box. Any tips on repairing this I have fluid on the lower a frame and underside of the frame . Thanks in advance.
blakkmaxx is offline
post #2 of 3 (permalink) Old Nov 26th, 11, 04:52 AM
Ron
Re: Leaking power steering Box
Where is it leaking from? The Hose Connections or around the Seals- If so do you have play in the Pittman or Input Spline?
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 3 (permalink) Old Nov 26th, 11, 06:09 AM
Guess
HwyStarJoe's Avatar
You can buy a new seal kit for the box and do it yourself if you want to save money. You can also make adjustments to it, if the internals aren't too worn. There are a couple threads here showing an exploded view of the box and how to go about working on it. I believe Jim Shea has several papers published on the procedures.
Replacing the hoses is always a good idea. Do them at the same time.
HwyStarJoe is offline
