Power steering vs rack and pinion - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 27th, 11, 06:02 AM Thread Starter
kenny
trying to figure out whats best for my set up 1967 bbc 396 with headers sounds to me like maybe a 80s-90s iroc power box any ideas ?
kenny g is offline
post #2 of 6 (permalink) Old Nov 27th, 11, 06:07 AM
Andrew
Andrew69's Avatar
Re: power steering vs rack and pinion
IROC box is the way to go.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 6 (permalink) Old Nov 27th, 11, 06:13 AM Thread Starter
kenny
thanks andrew thats what i'm leaning towards sounds like alot of probs with the racks
kenny g is offline
post #4 of 6 (permalink) Old Nov 27th, 11, 06:58 AM
Andrew
Andrew69's Avatar
When you get a little time read this discussion on the IROC box upgrade. https://www.camaros.net/forums/showthread.php?t=103139 The results a so good you don't need a rack and pinion.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #5 of 6 (permalink) Old Nov 27th, 11, 10:42 AM Thread Starter
kenny
Re: Power steering vs rack and pinion
thanks andrew good reading. do you know if the iroc box will give me any more clearance my factory manual box is almost right against header
kenny g is offline
post #6 of 6 (permalink) Old Nov 27th, 11, 01:59 PM
any power steering box will take up more room than a manual box.
what engine/mount/trans/trans crossmember/header combo are you running? if you've got a big block sitting on small block mounts or a 350 sitting in 307 mounts with headers designed for the 350 mounts, you are gonna have some clearance issues..
you don't plan sincerity.
novaderrik is offline
