Disc Conversion labor cost - Team Camaro Tech
post #1 of 15 (permalink) Old Dec 1st, 11, 03:32 PM Thread Starter
Hi Guys,
I want to install the Right Stuff conversion $595 kit from drums to to Disc on the front of my 67 Camaro and not willing to attempt it myself.
A local shop that builds race cars and street rods says if I buy the kit they will install for $800 ($95.00 per hour)
Does this sound reasonable?
Another 67
Another67 is offline
post #2 of 15 (permalink) Old Dec 1st, 11, 04:23 PM
DjD
DjD's Avatar
Re: Disc Conversion labor cost
Originally Posted by Another67 View Post
Hi Guys,
Another 67
Every region the labor rates are different, if $95 per hr is the going mechanical labor rate where you are at then it's okay.
...Dennis
DjD is offline
post #3 of 15 (permalink) Old Dec 1st, 11, 04:29 PM
Rick
To bad I'm not in WV, I just did this conversion on a 65 Nova SS for $200.00
FrostWhiteZ is offline
post #4 of 15 (permalink) Old Dec 1st, 11, 04:32 PM
Are all your ball joints, tie rods, and sway bar links in good shape? If you have any intentions to do those, then this is the time to do it. If they start taking things apart and those pieces are bad, then expect the price to go up.
As for the $800.......sounds reasonable as long as they stand behind their work.
You Can't Fake Indifference
69 Camaro Convertible
57 Chevrolet Nomad
Jeeps
buzzworth is offline
post #5 of 15 (permalink) Old Dec 1st, 11, 04:46 PM
Josh
200$!!!
How do you survive on 20$ on hour!??!
It's an 8-12 hour job depending on the kit and quality, some fabrication and cleaning up is usually necessary. Make sure they supply everything in the kit-hoses-proportioning valve, master cylinder etc.
Just so you know they are using the get out of jail free card..if you supply the parts they have no warranty and get paid each time they have to remove/install something....
Shop rates in my town are 100-165 an hour, I charge $100 an hour.
Grabbin2ndgear is offline
post #6 of 15 (permalink) Old Dec 1st, 11, 05:15 PM
Tony B
im getting robbed... I charge 30 an hour... but i dont own a business either with no overhead...
Your vehicle details go here
69Z28/SS396 is offline
post #7 of 15 (permalink) Old Dec 1st, 11, 05:25 PM
DjD
DjD's Avatar
When a shop charges $100 per hr labor rates employees are making about $25 per hr so you are doing good if you can stay busy...
...Dennis
DjD is offline
post #8 of 15 (permalink) Old Dec 1st, 11, 09:25 PM
john
wagonman's Avatar
thats very cheap considering you also had to convert the brake lines and master cyl over to a dual set-up........
I'll send some work up your way!
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #9 of 15 (permalink) Old Dec 2nd, 11, 02:29 AM
$95 per hour sounds like a dealer rate
They could be charging that high so you'll go somewhere else ? ? ?
Yes, it's about an 8 hr. job...and yes, might as well do new U & L balljoints while you're there
68 Camaro~LSx ~all motor
post #10 of 15 (permalink) Old Dec 2nd, 11, 09:59 AM
Russ
8-10 hours is not unreasonable as an estimate. Labor costs in CA range from $65-125/hour. Does this cost include alignment when they finish the brakes ? If you have the work done, make sure as others said that your ball joints and tie rod ends are replaced if not new already. Took me 4 weekends to do my conversion but I did both front and back and my a-arms spent one weekend getting hot tanked and repainted while I drank beer.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #11 of 15 (permalink) Old Dec 2nd, 11, 12:19 PM Thread Starter
All the front parts are new, I guess I should have done it then, but trying to do things as I can afford it
post #12 of 15 (permalink) Old Dec 2nd, 11, 01:01 PM
There is an easier -cheaper way to do it if you take your time
You won't need to touch your ball joints or remove the spindles
http://www.pozziracing.com/brakes.ht..._brake_spindle
and
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
post #13 of 15 (permalink) Old Dec 2nd, 11, 07:35 PM
scblucam's Avatar
Do your self a favor. If you own one of these cars you need to know how to do it your self. Even if you farm it out you will understand what the shop is asking.
68 302 M20 - 85 IROC Z
scblucam is online now
post #14 of 15 (permalink) Old Dec 2nd, 11, 09:06 PM
Steps
Thats interesting....a qualified tradesman mechanic in NZ gets around $NZ 25/ hr....thats about 30/32 US
A workshops most trades..plumbers, carpenters whatever have a charge out rate around the $NZ 65 to 85 /per
Then hit dealership franchise shops mechanics still get about the same and the charge out rate shoots up around the !20 + mark
my sentiments exactly...jusat follow the instruction sheet....and u learn how things work.
Steptoe is offline
post #15 of 15 (permalink) Old Dec 3rd, 11, 05:51 AM
Rick
Hey I would be satisfied if someone would just give me a job LOL!
