Bolt-on vs weld-in subframe connectors - Team Camaro Tech
post #1 of 29 (permalink) Old Dec 6th, 11, 02:57 PM Thread Starter
Eric
Is is going to make a big difference welding on subframe connectors over bolting then on if you have 850 fwhp in a 68 camaro with complete caltrac setup and good shocks with solid body mounts?
eric68camaro is offline
post #2 of 29 (permalink) Old Dec 6th, 11, 04:09 PM
Wes
Re: bolt on vs weld in subframe connectors
I use these bolt-ins on three 69's:
http://www.summitracing.com/parts/CEE-3112/
...and I welded them in. Works great!
Straight-line-69 is offline
post #3 of 29 (permalink) Old Dec 6th, 11, 04:11 PM
Michael Gekko
Welding them in will definately be better than bolting them in when having 850 hp under the hood. And, usually, the bolt in type tends to hang down lower and is more noticeable. At least the old school stuff did back in the day.
Eleanor's Nemesis is offline
post #4 of 29 (permalink) Old Dec 6th, 11, 04:26 PM
Bobby
850 hp at the rear wheels......holy smokes.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #5 of 29 (permalink) Old Dec 6th, 11, 04:27 PM
mark
Not hijacking just wondering if they require floor mods? Hate to cut a new one piece.
68 originally ss (straight six) 406,Afr210,Bullet solid roller,rpm airgap,QF750,th400,3.73 Eaton posi.11.02 @ 122.74
mark191 is offline
post #6 of 29 (permalink) Old Dec 6th, 11, 04:35 PM
JcGc's Avatar
Buy a set of Hotchkis subframe connectors, they hug the floor board.
1969 Camaro
JcGc is offline
post #7 of 29 (permalink) Old Dec 6th, 11, 06:09 PM
Bryon
bcm66's Avatar
If I was running a true 850 hp, it would be in a full chassis car.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #8 of 29 (permalink) Old Dec 6th, 11, 06:38 PM
mark
fwhp = flywheel horsepower. Still crazy ponies at the wheels
mark191 is offline
post #9 of 29 (permalink) Old Dec 6th, 11, 07:24 PM
Matt
I was probably looking at these as well.
'69 Camaro 350 / T56 Magnum / 10-Bolt
Built rear & 4-link coming soon...
6D9 Matt is offline
post #10 of 29 (permalink) Old Dec 7th, 11, 07:25 AM
Robert
ROBS6T8's Avatar
Re: Bolt-on vs weld-in subframe connectors
I went with the CE bolt ins and am happy with how they look(not hanging down). Heard nothing but good things with the Hotchkis SFC..
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread
ROBS6T8 is offline
post #11 of 29 (permalink) Old Dec 7th, 11, 11:20 AM
Greg
I run the bolt in CE's like in the link. I have thought about welding them in but I have a nightmare of a time getting one of the j-nut bolts started every time. I have to wiggle things around and hold my mouth just right to get it started. I am afraid if I welded the connector in place I'd never get it started.
Don't the Hotchkis require cutting the floorboard?
I am about 700 fwhp.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #12 of 29 (permalink) Old Dec 7th, 11, 12:31 PM
I have the bolt-ins and welded them....I heard they fit easier ?
68 Camaro~LSx ~all motor
post #13 of 29 (permalink) Old Dec 7th, 11, 06:27 PM
JcGc's Avatar
No, the Hotchkis SFC do not require any modification to the floor board. They are bolt in, but I'm going to weld mine in when my car comes back from the paint shop.
1969 Camaro
JcGc is offline
post #14 of 29 (permalink) Old Dec 7th, 11, 06:38 PM
Skip
Skeeter55's Avatar
Here are some pictures and welded in Hotchkis frame connectors.... NO MODS
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #15 of 29 (permalink) Old Dec 7th, 11, 09:44 PM
Hotchkis
Eric – The inexpensive bolt-in connectors are great for drag racing if your car is stock height or higher…and you’re only driving your car in a straight line. If your car is lowered and you’ll be driving it on the street (or you’re drag racing it and you improved support), you’re going to be much happier with our contoured subframe connectors that weld-in without cutting the floor pan. Talk to anyone who has switched from one set to the other. They do make a difference…and with 850hp your Camaro is going to need all the help it can get.
Hotchkis is offline
