Distribution Block - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 8th, 11, 08:02 AM Thread Starter
Distribution Block
Will the distribution block work with a manual 4 disk brake set-up? My car was originally a manual 4 drum set up and I installed a manual front disk brake conversion kit about a year ago...I've been using just the distribution block and the brakes work fine...I'm getting ready to do the rear disk brake conversion and was curious if I can still use just the distribution block...
Thanks...
U.S Air Force Retired
68 RS/SS, 396 BBC .060 over, M-20, 373 12 Bolt, factory color Island Teal blue, redline bias ply tires.
knuggles68RS/SS is offline
post #2 of 6 (permalink) Old Dec 8th, 11, 08:14 AM
Matt
Re: Distribution Block
Yes. I converted from 4 drum to 4 disk and used the same distribution block. I also added a proportioning valve for the rears.
Matt
zlek131 is offline
post #3 of 6 (permalink) Old Dec 8th, 11, 08:23 AM Thread Starter
Matt,
Thanks for the reply...Is the PV necessary?
post #4 of 6 (permalink) Old Dec 8th, 11, 08:37 AM
Matt
Depends on the setup...I went with Wilwood manual setup. They (Wilwood) claim that a PV is not necessary in this setup when using their tandem master cylinder but I went ahead and plumbed one in anyway. More of a "just in case" on my part. The idea of the PV is to decrease pressure to the rears and prevent lock up. I tried different settings on the PV and honestly I can't tell a difference nor have I ever had any lockup issues.
Matt
zlek131 is offline
post #5 of 6 (permalink) Old Dec 8th, 11, 08:50 AM Thread Starter
Thanks Matt...
post #6 of 6 (permalink) Old Dec 8th, 11, 03:01 PM
PA Camaro Guy's Avatar
X2. You wouldn't lock up on dry pavement without a PV. Or, if you did, it's not due to the absence of that PV. Where you might miss it is if your rear tires were on a slippery surface but the front are not. I think that was the basic design concept.
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
