67 camaro front disc caliper - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 12th, 11, 07:52 PM Thread Starter
jared
which way should the calipers be on a 67 camaro front disc, bleeder towards the top or should it be towards the bottom, not sure,and its been 4 or5 yrs since I took them off !!! I've got the drivers side on now and the bleeder is towards the top,and that caliper has the bigger hard line thread size than the other caliper ( The thread size that screws into the caliper )
jcfcamaro is offline
post #2 of 4 (permalink) Old Dec 12th, 11, 11:15 PM
Larry
larryh56's Avatar
Re: 67 camaro front disc caliper
Bleeders go on the top.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #3 of 4 (permalink) Old Dec 13th, 11, 03:53 PM
67 Camaros Rock
Joe Harrison's Avatar
Yes on top. If your converted from drum to single piston disc and using different parts you want calipers from a 69 Camaro, one from a chevelle will put the brake line at a odd angle.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #4 of 4 (permalink) Old Dec 13th, 11, 06:40 PM Thread Starter
jared
These are factory disc off my rs/ss!! I sent the master, prop valve, calipers to lonstar and had them all redone, man they look nice!!!! But its been a long time that I took them off ( doing a frame off resto ) So the driver side caliper should have the bigger threaded hole that the hard line screws into ????
