Brake problems - Team Camaro Tech
post #1 of 13 (permalink) Old Dec 17th, 11, 12:29 PM Thread Starter
Vic
Brake problems
Hi guys,
I have recently started getting problems with my brakes where when i push down on the pedal, it does not come back up, i will have to grab the pedal and pull it back up.
I am thinking it is my diaphram in my brake booster that is not responding, or could be inversed?
I have a tuff stuff booster, and got a stock master cylinder put in by my mechanic during inspection because my old on was shot...
anyways, my question is, can I get a Wilwood booster, and keep my stock master cylinder? or do i have to replace both if i want to have a wilwood? Also, my disc brakes are are stock disc's.
Vic
1969 Camaro SS
Camaro1969 is offline
post #2 of 13 (permalink) Old Dec 22nd, 11, 11:00 AM Thread Starter
Vic
Post Re: Brake problems
thanks for the numerous replies, always a great help
Vic
1969 Camaro SS
post #3 of 13 (permalink) Old Dec 22nd, 11, 07:21 PM
ern
ern
Re: Brake problems
so did you find the problem or are you still looking, i have the same problem but i bought the complete assm.
ern is offline
post #4 of 13 (permalink) Old Dec 22nd, 11, 07:36 PM
ern
ern
Re: Brake problems
by the way i did not see all the replys would like to see what people are saying, i sent tuff stuff an e-mail we will see what they say
ern is offline
post #5 of 13 (permalink) Old Dec 22nd, 11, 10:48 PM Thread Starter
Vic
Re: Brake problems
hey em, it was just a snarky remark i made because i didn't get any responses.
I am assuming it is that, and i am going to replace the master cylinder and the booster with a wilwood set
Vic
1969 Camaro SS
post #6 of 13 (permalink) Old Dec 23rd, 11, 12:18 AM
Filip
Re: Brake problems
As far as I know Wilwood doesn't make a brake booster. At one stage I had the same problem with the brakes and it turned out that the dust boot that covers the push rod was restricting it. I have since change to the Wilwood master cylinder with the Hyrdatech set up and its fantastic.
kiwicamaro is offline
post #7 of 13 (permalink) Old Dec 25th, 11, 03:23 PM Thread Starter
Vic
Re: Brake problems
yes sorry not a wilwood booster, i will have to find another after market booster.
Vic
1969 Camaro SS
post #8 of 13 (permalink) Old Dec 25th, 11, 10:41 PM
Todd
Re: Brake problems
Factory type booster/master cylinders require a pedal return spring.
Vegas69 is offline
post #9 of 13 (permalink) Old Dec 26th, 11, 07:41 AM
Dave C
Re: Brake problems
^^^ I am on the same page as Todd^^^
Talk to Wilwood thouraly before you buy and get all your ducks in a row.
It some times takes a few days for the right answer on here especialy aroun the holidays be patient.....
PRO.ST69orange
post #10 of 13 (permalink) Old Dec 26th, 11, 10:59 AM
Re: Brake problems
Factory PB systems do not use a return spring. Manual brakes do.
Sauron67MM is offline
post #11 of 13 (permalink) Old Dec 26th, 11, 11:50 AM
prostreet69camaro's Avatar
Re: Brake problems
Thats true,,,the booster pushes the pedal back up.
prostreet69camaro is offline
post #12 of 13 (permalink) Old Dec 26th, 11, 09:27 PM
Todd
Re: Brake problems
I'd have to check my assembly manual. You may be right.
Manual brakes with a Wilwood master does NOT require a return spring.
Vegas69 is offline
post #13 of 13 (permalink) Old Dec 26th, 11, 09:48 PM
Steps
Re: Brake problems
The normal response is simply "Bump"
And as mentioned above holidays etc, thu it is VERY rare even then a thread is not replied to.
From memory about that time there was a very similar thread with similar issues, which we may very well have not open this thinking ..assuming double post....
Even so did u even bother to run a forum search to get some sort of answer to your problem....As mentioned this subject has arisen sevferal times over the yrs and been delt with.
Steptoe is offline
