Steering column "wiring adapter" - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 18th, 11, 07:09 PM Thread Starter
Gordon
gordr's Avatar
Hi there,
I pulled out my 67 machine's non-tilt floor shift steering column intending to install a rebuilt tilt column.
In the photo below there was the adapter from column ribbon wires to the under dash semi-circled brown connector. Is this from a column shift column?
The tilt column has a matching semi-circled brown connector, but with different color wires. I'm guessing the tilt wiring will matching right up with the under dash semi-circled brown connector. Both have 8 wires with a blank 9th hole that matches up on both sides.
So, do I go ahead and just put it in there assuming the wiring will match up even though they are different colors?
The pix are below...the older appearing one is from the tilt column going in and the other is from under the dash.
Thanks,
Gordon
ID:	25934   Click image for larger version
ID:	25935   Click image for larger version
gordr is offline
post #2 of 2 (permalink) Old Dec 19th, 11, 03:04 AM
Re: Steering column "wiring adapter"
Match up the new column connector with the dash connector and the old column connector.
If colors don't match, then I would say the column connector wires have to be changed.
You can use a straightened small paper clip to release the lock pin for removing the pins.
The left picture showing a flat connector to semi-round connector is an adapter, a-a, b-b, c-c, etc. Whether it would be for a column shift, I have not a clue.
You might look for an article JimL82 has here about columns.
