Power Steering Conversion Issue - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 19th, 11, 05:54 AM Thread Starter
CHOPS
Ok, I've never seen this happen before. I did a power steering conversion on my 68 camaro. I used a 86z28 pump and box. Everything worked ok then the steering got really hard at low rpm and low speeds. I thought something may be clogged so I pulled the pressure valve out and checked it out. Seemed fine. Put it back together and it worked great for about 10 miles then back to the really hard steering. So I flushed the system and checked the valve again. Again, noticed nothing wrong. Put it back together and worked fine for another 10 miles then back to crappy steering. Any ideas where I should go with it from here?
BUFFDRIVER is offline
post #2 of 8 (permalink) Old Dec 19th, 11, 08:44 AM
Steiner
Re: Power Steering Conversion Issue
Describe the way your purged the air out of it.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 8 (permalink) Old Dec 19th, 11, 09:47 AM Thread Starter
CHOPS
I got the front tires off the ground and went from stop to stop with the wheel until no air was seen in the fluid.
post #4 of 8 (permalink) Old Dec 19th, 11, 12:05 PM
Brent
67Rally's Avatar
It could take 25-50 turns lock to lock to bleed the air. Also make sure your lines are tight, if air is getting in anywhere it will froth the fluid.
I did the conversion with a new PS box and didn't have the inserts for the pressure and return lines on the box so I wasn't getting a tight seal. It would be fine for 15-20 minutes of driving and then it would get very hard.
67Rally is offline
post #5 of 8 (permalink) Old Dec 19th, 11, 05:11 PM Thread Starter
CHOPS
Thanks man. I ran it lock to lock about 60 times (thanks to the help of my 6 year old daughter) with out the engine running. I got a lot of air out of it. Then I did the same thing with the engine running. I took it around the block and so far so good. I'll post the outcome tomorrow after driving it to work. Thanks again.
post #6 of 8 (permalink) Old Dec 19th, 11, 05:17 PM
Brent
67Rally's Avatar
Great, hopefully that's all it takes. However, I did the same with mine and thought it was fixed, and then I took it out for a 30 minute ride and ran into the same old problem.
Also, what are you running for hoses? One of the things that came up when I was trouble shooting was metric vs SAE fittings. Originally I was using a braided stainless hose with AN fittings, but ended up switching back to stock hoses. Two of the common metric/SAE sizes are almost interchangeable, meaning they will thread together, but may not create that perfect seal. Just another thing to check if you end up with more air in the line.
67Rally is offline
post #7 of 8 (permalink) Old Dec 19th, 11, 05:51 PM Thread Starter
CHOPS
I'm running stock lines. Everything is from an 86 Z28. What did you end up doing after your 30 min drive with the same issue? Just re-bleed it? Anything different?
post #8 of 8 (permalink) Old Dec 20th, 11, 11:19 AM
Brent
67Rally's Avatar
I had the same issue every time I drove it for a few weeks. I'd have to bleed it after every drive. It wasn't until I switched back to stock lines and got the correct inserts from Lee mfg. that I was able to resolve the problem.
67Rally is offline
