Front anti sway bar - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 20th, 11, 12:07 PM Thread Starter
mike
Front anti sway bar
I will try to keep this brief. !967 camaro 496 procharged 800hp range 6 speed standard 3.9 ford 9 inch rear to give a little background. I have slide a links drag radials and 90/10 shocks up front. I get a lot of front end travel and it helps hook so much so it ripped the antisway bar out of the frame. I removed the bar and repaired the frame. This is a street car and on the street going around turns is a new and slightly scary experience I am looking at a few ways to help with the body roll. I was thinking of putting the anti sway bar back in and using travel limiters on the front end and putting blocks under the mounts where the anti sway bars mount, I read on another thread this helps. My other thought was to use a rear anti sway bar but with the 3 inch exhaust it looks like it would be hard to find one that wont interfere. Plus I already have the front anti sway bar so$$$...If anyone could help I would truly appreciate it Thanks
bigblockragtop is offline
post #2 of 12 (permalink) Old Dec 20th, 11, 12:44 PM
Re: Front anti sway bar
Been there done that (street driving without swaybar) Don't like it
Anywho, yes I would reinstall...maybe wrap the frame with some 1/8"-3/16" flat stock on 3 sides minimum... fully welded of course.
68 Camaro~LSx ~all motor
post #3 of 12 (permalink) Old Dec 20th, 11, 12:54 PM Thread Starter
mike
Have you heard of putting blocks under the mounts on the frame rails? What about the travel limiters? Thanks
post #4 of 12 (permalink) Old Dec 20th, 11, 05:12 PM
Smile Re: Front anti sway bar
This is done to allow more space between the bar and the harmonic balancer on your engine. I don't know if there is any other advantage.
TJS69 is offline
post #5 of 12 (permalink) Old Dec 20th, 11, 08:04 PM Thread Starter
mike
I just thought the blocks would help so when the front comes up all the way it would not pull so hard on the mounts, that or using a-arm travel limiters I was just wondering if others have had any experience with doing either, or like I said skip that all together and just use a rear anti sway bar thanks for the replies it is truly appreciated. I was also told the torque twist would cause the bar in the front to twist causing it to rip out of the frame and especially on the passenger side which by the way ripped out first.
post #6 of 12 (permalink) Old Dec 21st, 11, 10:29 AM Thread Starter
mike
Hey If anyone has experience with their gen 1 camaro like I am having don't let this thread die out I could really use some help Thanks
post #7 of 12 (permalink) Old Dec 21st, 11, 10:41 AM
DjD
DjD's Avatar
Most high HP cars I've seen setup for the drag strip don't run a swaybar or if they do, they remove the end links before doing any hard launches. The swaybar works against the front end lifting and doesn't allow full weight transfer. In your case it's ripping the swaybar out of the frame...
I don't think adding a swaybar to the rear in place of the front bar would be of any benefit. If you want the car to corner you need to rethink the suspension mods and give up the dragstrip hole shot to gain cornering ability.
...Dennis
DjD is offline
post #8 of 12 (permalink) Old Dec 21st, 11, 11:15 AM Thread Starter
mike
the front shocks are adjustable to 80/20 and I think 60/40 would changing those settings be enough to have the sway bar not rip out?
post #9 of 12 (permalink) Old Jan 2nd, 12, 06:47 PM Thread Starter
mike
I realize cornering and drag racing are 2 different games but can't there be a little compromise between the 2 A little weight transfer and still keep the antisway bar. I am sure I can't be the only one with this dilemma.
post #10 of 12 (permalink) Old Jan 2nd, 12, 07:30 PM
DjD
DjD's Avatar
I think most guys looking to go around corners and drag race build their car for going around corners fast and kinda live with not having a dialed in quarter mile burner. Drag shocks and disc brakes for drag cars just don't cut it carving corners!
...Dennis
DjD is offline
post #11 of 12 (permalink) Old Jan 2nd, 12, 11:30 PM
David Pozzi
davidpozzi's Avatar
The problem is the front bar arms are too short and get into severe angles quickly when the front end rises. Do you have the factory rubber droop stops on the underside of your upper A arms? They pop into a hole in the A arm. Shock length can also be used to limit upward travel. Make sure your sway bar end links are long enough and not too tight.
davidpozzi is offline
post #12 of 12 (permalink) Old Jan 3rd, 12, 10:16 AM Thread Starter
mike
Thanks so much for your reply. The rubber droop stops are in place. The shocks are competition engineering I don't think I can adjust the amount they extend only the rate. I will check out your website to see the what length the end links are they came with the bar. As far as them being tight I had no idea they could be looser to tighter just thought tighten til they stop and go.
Are you saying the front end travel limiters may help though?
Thanks again
