Slide A Link - Team Camaro Tech
post #1 of 23 (permalink) Old Dec 20th, 11, 04:38 PM Thread Starter
Jon
Slide A Link
Anyone use Comp engineering Slide A Links on a 67 camaro with multi leafs? My shocks are currently mounted inbound on old school slappers. Can I mount shocks inbound on Slide A links? Do you recommend another traction device? Thanks...
JR67RS is offline
post #2 of 23 (permalink) Old Dec 21st, 11, 04:43 AM
Re: Slide A Link
http://calvertracing.com/cart/index....products_id=15
CalTracks seem to be very popular
68 Camaro~LSx ~all motor
post #3 of 23 (permalink) Old Dec 21st, 11, 05:46 AM
Brent
67Rally's Avatar
Re: Slide A Link
I was talking with a guy last week who does a lot of drag racing and has had every type of traction bar known to mankind over the years. He swears by the Slide-A-Links and says he wouldn't run any other kind nowadays.
Do you have a picture of the actual slide-a-link setup for the '67? I'm wondering if the shock plates have a bracket that is specific to left and right side. If so, you may be able to swap the left and right brackets to move the shocks inboard. If they are generic left and right parts, then I would think you could keep you in board shocks without modification (pure speculation here).
67Rally is offline
post #4 of 23 (permalink) Old Dec 21st, 11, 09:47 AM Thread Starter
Jon
Re: Slide A Link
http://www.competitionengineering.co...?CatCode=13116 Part # C2100. Looks like I may have two shock mount options??
JR67RS is offline
post #5 of 23 (permalink) Old Dec 21st, 11, 10:29 AM
bax
Re: Slide A Link
1967 mono
Kurler is offline
post #6 of 23 (permalink) Old Dec 21st, 11, 10:34 AM
mike
Re: Slide A Link
I have them on my 67 camaro street car and was amazed how much they helped the only thing I can say that may help is when normal driving adjust them with a little space to avoid the torque steer and I do have multileaf.
procharged 496 6speed manual ford 9 inch The other biggest help was drag radials and 90/10 shocks but if you search a thread I started I could use some help cuz with all that traction and front end lift it ripped the sway bar out.
bigblockragtop is offline
post #7 of 23 (permalink) Old Dec 21st, 11, 10:40 AM Thread Starter
Jon
Re: Slide A Link
Did yours come with two lower shock locations?
JR67RS is offline
post #8 of 23 (permalink) Old Dec 21st, 11, 10:55 AM
Brent
67Rally's Avatar
Re: Slide A Link
If you look at Kurler's top picture, it looks like there is only an outboard shock location, unless the inboard mount was ground or cut off.
The picture of the 2100 from CE's website shows that there are two locations.
However, even if they are like Kurler's, I still think you could swap the left and right brackets to move the shock inboard.
67Rally is offline
post #9 of 23 (permalink) Old Dec 21st, 11, 11:42 AM Thread Starter
Jon
Re: Slide A Link
Thanks! Ordered them up
JR67RS is offline
post #10 of 23 (permalink) Old Dec 21st, 11, 01:12 PM
Wes
Re: Slide A Link
I'm sure Slide-a-Links are great products (cetainly better than slapper bars), but like Doug G below (and 1000's of others) I use Cal-Tracs on four cars.
When I evaluated my options several years ago, I never could understand how you set consistant pre-load ad with something 'slides'.
Enlighten me.
Straight-line-69 is offline
post #11 of 23 (permalink) Old Dec 21st, 11, 01:14 PM Thread Starter
Jon
Re: Slide A Link
I was going to go cal-tracs but was told they work better with there split mono leaf
JR67RS is offline
post #12 of 23 (permalink) Old Dec 21st, 11, 06:13 PM
Jeff
Re: Slide A Link
My slide-a-links have both inner and outer mount locations.
Jeff
- 400 Dart Little"M", SRP 10.2:1, 4340 Scat rotating Assy, Solid Roller, AFR 210 Eliminators, Jesel shaft rockers,Super vic, Prosystems 847CFM, Tko600, 12 bolt 4:10 Eaton posi W/ Strange Hy-Tuf race axles and eliminators.
Best E.T. (11.96 @ 118.06) N/A
Classic Copper 4 Spd
jcdubs is offline
post #13 of 23 (permalink) Old Dec 22nd, 11, 04:18 AM
Re: Slide A Link
Well.... you may want to read this before you install
https://www.camaros.net/forums/showth...bent+slid+link
post #14 of 23 (permalink) Old Dec 22nd, 11, 04:28 AM Thread Starter
Jon
Re: Slide A Link
Thanks Doug. After reading I put a pause on my order. Do the cal tracs work with multi leaf? Your a racer whats your feelings?
JR67RS is offline
post #15 of 23 (permalink) Old Dec 22nd, 11, 06:21 AM
Re: Slide A Link
4-leaf multi's in mine with (Home built copies) CalTracs... working good for me
And I haven't heard of anyone bending CalTracs (from power). and there are thousands out there.
There is also a new player in the market and have got a lot of good replies from the really fast guys (also looks easier to install since you don't remove the front leaf eye)
http://srdparts.com/index.php?page=s...emart&Itemid=1
