Tire rubbing issue and noise on front - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 21st, 11, 09:38 AM Thread Starter
Brent
Okay so I have recently bought new wheels, cragar 15x7 in fronts with 4-1/8 backspacing. I took the car out this morning because I also just put a new steering wheel on and wanted to make sure it was aligned before I thightened it. I noticed when I got it out that when I turned it to the right it made a noise. I took it back home and looked at the front and noticed I had about a 3/4" gap in the passnger side and it was slightly rubbing ( no gap) on drivers side between the tierod arm and the tire. Did I get to much of a backspacing on the front? Can I adjust the tierod somehow and and still have it be aligned? I assume so since there is a gap on the passenger side and not on the drivers side. Car is a 67 camaro.
tbd67 is offline
post #2 of 8 (permalink) Old Dec 21st, 11, 04:59 PM
Bobby
Re: Tire rubbing issue and noise on front
What size tire?
I run 15x7 with 4 1/4 backspace and 215 65R15 with lots of clearance all around.
edit: I just took a look at mine and I have about 1" clearance on each side of the tie rod end to the tire.
I'd say your issue is in the steering linkage.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #3 of 8 (permalink) Old Dec 21st, 11, 05:25 PM Thread Starter
Brent
The tire is a 225/60/15. I also have hotchkis 2" drop springs.
tbd67 is offline
post #4 of 8 (permalink) Old Dec 21st, 11, 05:39 PM
Bobby
Tie rod end connects to the steering arm which is bolted to the spindle.
I'm no expert but, either you have bent steering arm on one side or mismatched backspacing on the front rims. Did you measure back space before install?
67 Camaro 350
M20 4spd console,
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #5 of 8 (permalink) Old Dec 21st, 11, 08:07 PM Thread Starter
Brent
No, I never thought to check the backspacing when I got them.......
tbd67 is offline
post #6 of 8 (permalink) Old Dec 22nd, 11, 02:29 PM
Bobby
Me neither, guess I got lucky.
67 Camaro 350
M20 4spd console,
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #7 of 8 (permalink) Old Dec 31st, 11, 03:14 PM
Hotchkis
Tbd67 – If we’re understanding you correctly, it sounds like you have one long steering arm off of a different car (like maybe a ’74 Nova). There were at least 3 different length steering arms that will bolt onto the first gen Camaro spindle.
Here’s a picture from David Pozzi’s Camaro suspension page:
http://www.pozziracing.com/camaro_steering.htm
Hotchkis Sport Suspension
Toll Free: 888-735-6425
Hotchkis is offline
post #8 of 8 (permalink) Old Dec 31st, 11, 07:38 PM Thread Starter
Brent
I will measure them tomorrow to see if they are the sane length. Ihad the car at hibdon today checking the alignment. Wish I would have thought to check the lengths while it was up on the lift.....
tbd67 is offline
