Question about my steering column - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 24th, 11, 10:48 AM Thread Starter
kelly
what is the plastic white piece at the bottom of steering column? this is off my 67 camaro deluxe interior. i have another steering column from a 68 and it does not have this part. my friend has a 67 camaro and his does not have it either. i have not found it in any parts listing as well.
kellys69camaro is offline
post #2 of 4 (permalink) Old Dec 25th, 11, 06:55 AM
Re: Question about my steering column
The 1967 start of production steering column lower bearing had a threaded plastic adjuster that took up the length tolerance between the various steering column parts. The plastic threaded adjuster was quickly redesigned and replaced with a clamp, nut, and bolt design. So you must have an early 1967 steering column.
This is a comparison of Early and Late 1967 Corvette steering column lower ends. The parts are not identical to the Chevelle but the basic concepts were the same.
I would think that you should be able to obtain a late 1967/1968 lower bearing, adapter, clamp, nut and bolt to update the lower end of your steering column.
JIML82 is offline
post #3 of 4 (permalink) Old Dec 25th, 11, 07:38 AM Thread Starter
kelly
jim,
thank you for the reply. can i just order this.
http://www.ebay.com/itm/1967-1968-Ca...24946507357823
post #4 of 4 (permalink) Old Dec 25th, 11, 07:51 PM
I would think that you could use the lower bearing and adapter in that add. I just don't understand why that same bearing and adapter wouldn't work on a tilt column as well. I am quite sure that the lower end of a tilt column uses the same bearing types as the standard (non-adjustable) type.
JIML82 is offline
