Steering column length problem? - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 27th, 11, 11:03 AM Thread Starter
1969 Camaro w/tilt wheel. P/S (changed to IROC fast box)
Removed the column to paint the car. Put in a new Iroc box, new steering box side coupler and when we went to install the column it wouldn't line up to the dash bolts. The dimension from the firewall to the coupler flange on the column is identical to the picture/ruler in page 2 of this post. https://www.camaros.net/forums/showth...t=67155&page=2
4" 13/16
If you put the column in without the coupler the end of the column hits the steering box output shaft. It appears as if the column needs to collapse about 2"s or so to line up.
The steering box appears identical and the coupler is the correct one for the Iroc box change-out. based on the picture in the above post we must have the correct box and coupler.
Can the column collapse? Could it of expanded during the removal?
mtrhead is offline
post #2 of 5 (permalink) Old Dec 27th, 11, 12:04 PM
Guy
Re: Steering column length problem?
yes they do collapse, itry pulling it out. it is for safety.
jl8z28 is offline
post #3 of 5 (permalink) Old Dec 27th, 11, 01:26 PM Thread Starter
How much force is needed?
We tried usinga big screw driver when the coupler was removed to move the shaft up towards the fire wall. Should we be pressing from inside the car against the dash reinf with everything else bolted in? I dont want to damage a perfectly nice column
mtrhead is offline
post #4 of 5 (permalink) Old Dec 28th, 11, 12:14 PM
Steps
Do u mean the coluum or the main sterring shaft?
If the shaft..go back to some of my orginal threads around 2004/2005 I think..
The shaft is in 2 bits one sides inside the other and a thin nylon 'thread' stops them from sliding...IF one uses a mallet to free the steering wheel or pulls like hell....doesnt use a elcheapo chinese steering wheel puller, the thread breack and the sharft becomes the wrong length.
And the amount of force required varies from car to car over the yrs
Check out my old orginal threads..it has a step by step, lengths distances how to etc etc.
Steptoe is offline
post #5 of 5 (permalink) Old Jan 21st, 14, 06:36 PM Thread Starter
Its been two years, back working on my car and i cannot mount the column under neath the dash. I need the column to collapse about 1" to effectively line up the two studs under the dash.
Again its the original column repainted and all I changed was the iroc box and coupling.
I need the dimension in this picture from some cars to determine if my dash got bent down or something else is messed up.
Name:	steering to dash.jpg
mtrhead is offline
