Help - Coil Spring C-7412-1A - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 27th, 11, 08:27 PM Thread Starter
Eric
Depthrecordings's Avatar
Hello everyone,
I need a little advice here. I bought my coil springs (C-7412-1A) about 12 years ago when I started stacking up parts for my car. I looked online and I found a website (NPD?) that lists these as Hotchkis springs, but I am unsure if that is accurate: http://shop.autocraftinvestments.com...320&parent=845
I can not locate any other information on the springs, and I am trying to figure out if they will work and not leave the nose of my girl up in the air like she is from Beverly Hills I'm looking for a lower stance on my girl. The springs say high rate????
The problem if you call it that, is that the springs were listed as a 2 inch drop springs, however it looks like from the pictures below, the spring is actually much taller than the stock spring. Is this right? This is the first time I have ever replaced the front suspension in a Camaro, so I am not sure if the spring drops over time, or what. I hope I have listed enough info here to give you an idea of what I am trying to figure out. Any help would be much appreciated!
Car details:
Small block
Cast iron heads
No AC
Eric.B
Denver, CO
1967 Camaro
Depthrecordings is offline
post #2 of 7 (permalink) Old Dec 28th, 11, 09:28 AM Thread Starter
Eric
Re: Help - Coil Spring C-7412-1A
I guess I should mention thatthe stock springs came out of a 6 cyl car.
Thanks,
Eric
Eric.B
Denver, CO
1967 Camaro
post #3 of 7 (permalink) Old Dec 28th, 11, 02:04 PM
DjD
DjD's Avatar
Your's are not the right color and too long for Hotchkis drop springs... Yours look like stock SB replacment springs.
Hotchkis PN 1907F
...Dennis
DjD is offline
post #4 of 7 (permalink) Old Dec 28th, 11, 03:45 PM
Aaron
BigDawgDavao's Avatar
My guess is they'll turn your car into a 4X4, like the stock replacements springs from Classic did to mine. I ended up going with the proper Hotchkis.
The link you posted says they should be grey powdercoated, which Hotchkis are. Yours are blue? I think you got sent the wrong ones.
BigDawgDavao is offline
post #5 of 7 (permalink) Old Dec 29th, 11, 08:34 AM Thread Starter
Eric
Well I bought them 12 years ago from NPD and I doubt I can return them now. Crap! They have the same part number. I wonder if Hotchkis ever made them in Blue? O well.
Should I cut them or just buy the dropped springs? What are the disadvantages of cutting the spring?
My front suspension is set up as follows:
Stock Lower control arm, Moog lower ball joints, SPC adjustable Uppers(SC&C stage 2 plus) with NASCAR tall ball joints, stock spindles(modified to work with 69 Chevelle disc brakes), and Koni Shocks.
Around every corner theres another 2 or 3 hundred dollars to spend...LOL
Eric.B
Denver, CO
1967 Camaro
post #6 of 7 (permalink) Old Dec 29th, 11, 11:34 AM
David Pozzi
davidpozzi's Avatar
Those coils are too tall and the wire dia looks too thin to be a performance drop spring. I would not use them. Most stock replacement coils leave the front end too high and are too soft to work well if you cut them down. We have a great spring thread going here: https://www.camaros.net/forums/showthread.php?t=103250
In general, you need a stiffer shorter coil. For a guy with stock type tires and 15" wheels, the Moog coils 6308 and 6320 are nice, shorter and stiffer but not twice as stiff like the tuner springs. If you are using 17" or 18" rims and want the car to sit very low, then you need stiffer aftermarket coils in the 600+ range and shocks that are tuned to still give you a decent ride. Stiffer coils can ride well if your shocks are right.
davidpozzi is offline
post #7 of 7 (permalink) Old Dec 29th, 11, 12:51 PM Thread Starter
Eric
David,
Thanks so much for the info. I will do some checking on the coil spring thread. Your info has come in very handy!
Thanks again,
Eric
Eric.B
Denver, CO
1967 Camaro
