Calvert split mono leaf spring & pads - Team Camaro Tech
post #1 of 25 (permalink) Old Dec 28th, 11, 01:05 PM Thread Starter
Nev
Hi all,
Just bought some Calvert split mono leaf springs for my 68.
Do I use the upper and lower rubber spring pads from the original springs with the Calvert springs?
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #2 of 25 (permalink) Old Dec 28th, 11, 01:22 PM
Re: Calvert split mono leaf spring & pads
Not 100% sure (I don't have them) but I think they are suppose to be left out and there's not room for them anyway.
68 Camaro~LSx ~all motor
post #3 of 25 (permalink) Old Dec 28th, 11, 01:52 PM
Greg
What sping perches are on your differential....mono or multi? Does the perch have a cut out that the leaf spring pin sits in to center it?
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #4 of 25 (permalink) Old Dec 28th, 11, 01:54 PM
Greg
Just saw your other post....if you bought the spacer kit from Calvert that is all you need.
Greg O is offline
post #5 of 25 (permalink) Old Dec 28th, 11, 10:29 PM Thread Starter
Nev
I have a 12 bolt Moser with single leaf perches
These are the springs and spacers
This is the pin on upper face of spring (I am assuming the spacer is located on this "pin")
This is the underside of the spring / pin (which is basically the nut on the thread of the pin) I assume this locates in the hole of the spring/shocker plate
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #6 of 25 (permalink) Old Dec 29th, 11, 05:40 AM
Greg
Mine are multi perches so the spacer kit had one for the top of the spring and one for the bottom. I guess the mono has top only. Anyway, definitely no need for the rubber spring pads witih this setup.
Greg O is offline
post #7 of 25 (permalink) Old Dec 29th, 11, 05:05 PM Thread Starter
Nev
Thanks for the info and photo.
Do you think there is any extra noise when comparing old spring with rubber spring pads to the calvert spring with steel to steel?
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #8 of 25 (permalink) Old Dec 30th, 11, 09:22 AM
Doug
I just purchased the spacers for my 67 Camaro to install the Caltracs. They sent me the uppers you have and a pair for under the leaf springs. The bottom spacers have a larger sleave to fit around the nut on bottom of leaf spring. Looking at the new spring pad the hole is large enough to bolt together without the bottom spacers. Good Luck.
Cdminter55 is offline
post #9 of 25 (permalink) Old Dec 30th, 11, 12:53 PM
Greg
I don't think the pads will contribute to noise much but it has been a loooong time since I had rubber pads and can't really remember.
The only squeeking I ever got was from the front spring eye bushings if I had negative preload on the bars (an actual air gap between the stopper and the spring). It was not bad and went away now that I run the slightest pre-load.
Greg O is offline
post #10 of 25 (permalink) Old Dec 30th, 11, 03:44 PM Thread Starter
Nev
Ok, so now I know I should have the spacer on the top of the spring but I have another issue / question.
The nut on the bottom of the spring seems to be a lot smaller than the hole in the shocker plate (see pic)
Am I missing something that will locate the spring / nut positively into the shocker plate?
I am concerned I will get some movement which could cause bigger issues over time.
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #11 of 25 (permalink) Old Dec 30th, 11, 04:17 PM
Jon
What exactly is the spacer kit for? Are you able to get the ride height you desire and is there any problems with adjusting pinion if needed. I've been looking at these for a while.
JR67RS is offline
post #12 of 25 (permalink) Old Dec 31st, 11, 12:32 AM Thread Starter
Nev
My car is originally mono leaf and when I purchased the springs from Calvert they advised the spacer is required for cars with mono perches.
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #13 of 25 (permalink) Old Dec 31st, 11, 06:05 AM
Nev,
If you have enough threads on the center bolt get a thick washer or sleeve made that fits the hole diameter of the lower shock plate and install it under the nut to locate the shock plate.
schnide is offline
post #14 of 25 (permalink) Old Dec 31st, 11, 08:10 AM
dave
forgive my ignorance,but what does this spring setup do for performance?
dave lucas is offline
post #15 of 25 (permalink) Old Dec 31st, 11, 02:16 PM
Greg
i wouldn't be afraid to run it as is but if you are worried, call or e-mail Calvert. I don't have a mono perch on mine so I can't really tell you for sure.
Greg O is offline
