1 3/16" (solid) sway bar - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 2nd, 12, 11:42 AM Thread Starter
DjD
DjD's Avatar
Just put a pair of calipers on the sway bar on my '69 ragtop. It is 1 3/16" thick and a solid bar. I don't think it was from the factory. Other than the weight factor would there be any benefit in replacing it? It's a fairly stout piece.
...Dennis
DjD is offline
post #2 of 7 (permalink) Old Jan 2nd, 12, 02:16 PM
DT
Donny
DT's Avatar
Re: 1 3/16" (solid) sway bar
Dennis, I really don't think so. I would leave it. Just my .02 cents.
DT is offline
post #3 of 7 (permalink) Old Jan 2nd, 12, 05:31 PM
David Pozzi
davidpozzi's Avatar
With a bar that stiff you should be having terminal understeer even with a good sized rear bar. I'd replace it with a Hotchkis bar since you have their springs.
davidpozzi is offline
post #4 of 7 (permalink) Old Jan 2nd, 12, 06:26 PM Thread Starter
DjD
DjD's Avatar
Thanks for the replys guys! The car takes a corner fairly well but when pushing thing the front does tend to not want to turn and the back end always stays put unless applying power. I've never had a rear sway bar on the car but thanks to Christmas I do have a Hotchkis rear sway bar and I rounded up one of their sway bar braces (thanks Bob). It should be interesting to see how the car reacts with the rear bar installed.
...Dennis
DjD is offline
post #5 of 7 (permalink) Old Jan 2nd, 12, 11:25 PM
David Pozzi
davidpozzi's Avatar
If you want to try a Hotchkis front bar, I can loan you one.
post #6 of 7 (permalink) Old Jan 3rd, 12, 08:56 AM Thread Starter
DjD
DjD's Avatar
Thanks David, let me get the rear bar on and see how that changes things.
...Dennis
DjD is offline
post #7 of 7 (permalink) Old Jan 3rd, 12, 11:21 AM
Russ
Sounds like it may be an old Adco sway bar. I had a 1 5/8" solid bar from Adco on my 71 bird in the early 80's. Perfectly good product for street use.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
