Brake Booster & Master Cyld. - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 4th, 12, 12:29 PM Thread Starter
Bucky
Hello!
I am converting my old ride to a power brake set up. The car was already converted to discs in the front.
I am looking at buying a booster/master cyl set.
I want to try and keep the original look and I'm wondering what size booster everyone else has used? I know these are usually an 11 inch booster but do some people use the 9 inch and why besides just having a smaller booster using less real estate under the hood?
Just looking for ideas or a reason to justify a decision?
Thanks!
1967 RS Convert. numbers matching 327/275 with 4 speed hurst on top of a saginaw, 12 bolt 355 rear end, console w/gauges & deluxe int., ORIGINAL PLUM!
Let's Roll!!
imbucky is offline
post #2 of 2 (permalink) Old Jan 4th, 12, 12:32 PM
Camarodude67
Re: Brake Booster & Master Cyld.
An easy search, this is close to stock as you can get, if you have big block
with big valve covers then a 9 inch booster would help.
http://www.ebay.com/itm/Gm-Delco-Mor...item2c61cddb66
Jeff G.
camarodude67 is online now
