Steering Column Help - TKO Install - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 5th, 12, 02:10 AM Thread Starter
Todd
wondering if someone can tell me what this lever (in the photo) is for. It is located on the bottom of the steering column and hooks into some linkages that attach to the frame of the car. I am installing a tko and it does away with the linkage that attaches to this.
Todd J.
69 Vert, ZZ454, TKO600, Moser 12 Bolt, Hotchkiss Susp front & Rear - In The Works
Toads69 is offline
post #2 of 11 (permalink) Old Jan 5th, 12, 03:52 AM
Matt
Re: Steering Column Help - TKO Install
That lever connects to the reverse lockout linkage which connects to a lever on the side of your transmission better known as the reverse lockout.From the factory the car would need to be put into reverse in order to remove the key from the ignition effectively locking the car in reverse with the key removed.It also actuates the reverse back up light switch which is located on the top of the steering column.If you go with a TKO ,the linkage and bell crank on the frame will not be needed because the TKO has an internal back up light switch inside of the transmission.Hope this helps.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #3 of 11 (permalink) Old Jan 5th, 12, 09:37 AM Thread Starter
Todd
Thanks Matt
Todd J.
Toads69 is offline
post #4 of 11 (permalink) Old Jan 5th, 12, 10:54 AM
The lever on the steering column and the linkage to the shifter on the transmission was part of the General Motors, Steering Column/Transmission Shift Interlock System. When locking steering columns first became available in 1969, GM was very concerned that a driver might (for some reason) lock their steering column (and steering wheel) while the car was still moving straight ahead. So they came up with a backdrive system that required that a manual transmission had to be shifted into REVERSE or an automatic trans had to be shifted into PARK before the ignition key could be rotated to OFF-LOCK, the steering column locked, and the ignition key removed from the lock cylinder.
So with your 1969 (even though there is no longer a linkage system) you will need to rotate that lever on the lower end of the steering column to the full UP position (full CCW and about 1 o'clock if you could look down the steering column from the driver position and see it.) You will need to premanently lock it in that position. You will find that if the lever is in any other position, you will be able to shut off your engine, but you will not be able to lock your steering column and/or remove your ignition key.
You can hacksaw the lever off, but you will still need to come up with a method of fixing the shift tube in that full CCW 1 o'clock position.
The only drawback to removing the system is that you now could lock the steering wheel with the car rolling straight ahead.
JIML82 is offline
post #5 of 11 (permalink) Old Jan 6th, 12, 11:33 AM Thread Starter
Todd
I think I would like to keep the steering column in tact. Is any of the Tremec packaging vendors providing a position lock mecahnism for this?
I suppose a block plate could be fabricated to prevent it from moving???
Todd J.
Toads69 is offline
post #6 of 11 (permalink) Old Jan 6th, 12, 01:02 PM
Matt
You could just be creative and fab up a lock plate to hold the lever in position.It won't be that visible when you are done.Not to go off topic,but I see you have a ZZ 454 in your car.I have been considering this motor for myself for some time.Do you have any feed back about it either positive or negative? Are you happy with the power of this motor? Does it run well? How many miles do you have on it? Would you recommend it to someone else? Sorry for the pile of questions,I am just trying to get some real world feed back.Thanks.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #7 of 11 (permalink) Old Jan 6th, 12, 03:27 PM Thread Starter
Todd
Matt - My cars not together yet so can"t really comment yet. I did have my carb custom calibrated and broke the engine in on the Dyno. Pulled 470hp at 5200rpm on the Dyno basically out of the box. I hope to have it running this summer.
Todd J.
Toads69 is offline
post #8 of 11 (permalink) Old Jan 6th, 12, 04:16 PM
no need for anything fancy to hold it in place- a piece of wire will work to tie it up and you can just turn the column by hand inside the car if the key won't turn back to the "lock" position.. and it's really easy to run a couple of wires from the factory reverse light wiring that plugs into the switch on top of the column down to the switch on the side of the new trans.
you don't plan sincerity.
novaderrik is offline
post #9 of 11 (permalink) Old Jan 6th, 12, 07:15 PM
Max Stewart
Send a message via Yahoo to bigbuckcity
I have this on my 69 Camaro Convertible with a 4 Speed, you have to put the Transmission in Reverse to get the Key out of the ignition..................
bigbuckcity is offline
post #10 of 11 (permalink) Old Jan 7th, 12, 04:29 AM
Matt
Thanks for the feed back Todd.Good luck with the build.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #11 of 11 (permalink) Old Jan 7th, 12, 04:26 PM
When I rebuilt my 69 column, I just added some 3M Strip Calk around the inner tube that the tab is part of, so that it was stuck (but not irremovably so) to the outer column and could not rotate. Been that way for more than 5 years, no issues. Figured that was cleaner than having a safety wire running to some fixed point...
Eric
Eric Kammerer is offline
