11" Booster with 350 & tall valve covers? - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 8th, 12, 02:03 PM Thread Starter
Hi All,
I am ready to order my front Power Disc Conversion kit for my 67 Camaro and I am confused about all the boosters available. I want the original look so I was going with the 11" booster that gives the "factory look" from Right Stuff or Matt's, but I have tall valve covers on a 350 motor and it looks tight, will this work or should I go with a 9" single or dual diaphram.
I read that smaller booster = less assist at the pedal
Another67 is offline
post #2 of 5 (permalink) Old Jan 8th, 12, 06:05 PM
Re: 11" Booster with 350 & tall valve covers?
I have an 11" booster and tall valve covers on a 350 in a 69 and can remove and reinstall the valve cover without issue, although it is a little tight.
reelknots is offline
post #3 of 5 (permalink) Old Jan 8th, 12, 08:03 PM
PA Camaro Guy's Avatar
Here is a picture of the Right Stuff 11'' booster on my small block with standard valve covers. You can see that it is kinda tight--- tall ones *might* hit but they are taller on an angle, so that's something to consider..
http://www.flickr.com/photos/3612672...in/photostream
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
post #4 of 5 (permalink) Old Jan 9th, 12, 05:24 AM
Here's a view of mine with tall covers. As I said, I was able to remove the cover to retorque the head and then reinstall. It was tight but doable.
ID:	26274   Click image for larger version
post #5 of 5 (permalink) Old Jan 9th, 12, 05:30 PM Thread Starter
Thanks Reelknots, nothing better than pics, I think I'm ready to order my conversion kit, I really appreciate the help
