68 suspension question - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 8th, 12, 04:08 PM Thread Starter
thefley
I would like to fix the lean on the rear on one side and the sway and bad ride when driving so I came down to a new whole suspension kit. The ones I find say a 2 inch drop. Where can I find one with out a drop?
First Gen Camaro Connections on Facebook
thefley is offline
post #2 of 6 (permalink) Old Jan 8th, 12, 05:52 PM
ern
ern
Smile Re: 68 suspension question
you could just replace with new stock items or go with coil over ft some more details would be nice i just set up that will work with stock arms if they are good and new rear springs and sway bars ft and rear it all depends on what you want. some more details would be nice ,i redid mine it is a 69 i have some pictures on this form
ern is offline
post #3 of 6 (permalink) Old Jan 9th, 12, 06:25 AM Thread Starter
thefley
I am trying to fix the roll and sway while driving, it is stock I believe and it came with a 6 cylinder now has a 350. I tried adjusting front spring on drivers to see if that would help the sag on right rear. I have 17X10s on back and 17X8s on front and worry about the full suspension kits saying it will lower the car.
What other info would you need me to post?
thefley is offline
post #4 of 6 (permalink) Old Jan 9th, 12, 07:06 AM
Rick
http://www.jcwhitney.com/replacement...id=d244y1968j1 If you have mono leafs you'll have to change the spring perches on the diff, if you already have multi-leaf perches you will be ready to go.
FrostWhiteZ is offline
post #5 of 6 (permalink) Old Jan 9th, 12, 12:04 PM
steve
I just installed the Hotchkis 2" drop leaves on mine. They were multileaf but allowed you to install in the mono leaf spring perch without issue. The Jegs P/N was 515-2407c and the price was $419.99. I contacted Hotchkis directly to get the true specs:
"The stock mount will work with our rear leaf springs.These spring will lower the rear 1.5 inches and have a spring rate of 150-180 lb's per inch. It is stiffer than stock but not teeth jarring."
sflippen is offline
post #6 of 6 (permalink) Old Jan 9th, 12, 02:21 PM Thread Starter
thefley
That's the issue, I don't think I can handle a drop of 1.5 inch the right side sags about that much and I have tire rub when i turn into the drive and at other times
thefley is offline
