69 steering column - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 11th, 12, 05:52 PM Thread Starter
69 steering column
I posted a thread in the classifieds for the part I need to fix up my column, but as there was a technical question about compatability between parts, I thought I'd ask here.
The part I'm working on is the upper housing for the ingnition lock/key cylinder. It's also where the turn signal arm and hazad flasher knob are located.
Originally, my car was a column shift automatic, that was converted to a floor shift. I found a place that has the upper housing, but it's for a column shift manual.
Does anyone know if the upper housingwould be the same for an auto or a manual. seems like they could be the same since the shift column for both types is actually below and seperate from the upper housing. Unless there was some kind of internal difference...any help is much appreciated..
oldschool67 is offline
post #2 of 4 (permalink) Old Jan 12th, 12, 04:47 PM
Andy
Re: 69 steering column
Same part for both columns.
A Schab is offline
post #3 of 4 (permalink) Old Jan 12th, 12, 07:20 PM
I agree. My steering column assembly drawing shows the manual transmission (column shift) bowl is the same as the automatic transmission (column shift) bowl.
JIML82 is offline
post #4 of 4 (permalink) Old Jan 13th, 12, 06:33 AM Thread Starter
thanks for the feed back guys....I'm gonna go for it and order the housing so I can keep my original column.
