Global West Uppers - need Shims? - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 31st, 14, 09:20 AM Thread Starter
I'm finally in my build where I can re-assemble my subframe and suspension.
I'm installing GW ucas with stock lowers, delalum up/lower , Koni Classics and 2" lowering springs and new stock height spindles. All new moog steering replacement parts. Thanks all for the long list of part numbers.
Question: Should I leave the shims for the UCAs to the alignment shop? I saw a YouTube vid where the builder said an 1/8 shim would get it close, but he only put one on the rear cross shaft stud.
I'm wondering how to proceed. Thanks.
norcal_68 is offline
post #2 of 7 (permalink) Old Jan 31st, 14, 10:37 AM
Jeff
Re: Global West Uppers - need Shims?
As far as I know every car with fixed a-arms is going to require shimming. The amount of shimming required will be different for every car. I wouldn't want to go very far without some kind of ballpark alignment. You should be able to plumb the front wheels close to level ( 0 camber ), (with the weight of the car on them) and use string or straight edges to get the toe close to nuetral (0). I wouldn't think you'd need to worry about caster at this point. That should be good enough to get to the shop without causing much wear.
Good luck.
And this too shall pass.
69 X11 SS, Glacier Blue, LS3 480, T56 Mag, Lots of stuff done to it, all by yours truly
Build thread:
workng247 is offline
post #3 of 7 (permalink) Old Jan 31st, 14, 10:41 AM Thread Starter
Thanks, I should have mentioned my car has no engine. I'm literally reassembling it from having the subframe powder coated and moving on to building my motor. So it won't be driving anywhere for awhile. Just trying to get all the parts out of boxes and onto the car.
post #4 of 7 (permalink) Old Feb 2nd, 14, 02:28 PM
David Pozzi
davidpozzi's Avatar
I'd put two 1/8" shims in per bolt as a starter.
davidpozzi is offline
post #5 of 7 (permalink) Old Feb 5th, 14, 10:31 AM Thread Starter
Thanks, will do!
post #6 of 7 (permalink) Old Feb 5th, 14, 10:48 AM
Fred
Pictures! First gen builds are illegal unless you send your buddies pictures.
Oh wait, I forgot this: If for any reason you don't want to run GW upper arms, here's a product that uses turnbuckles instead of shims. Mine will be installed shortly.
http://www.summitracing.com/search/b...g&autoview=SKU
128.79mph 1.428 60'
Fred Ficarra is offline
post #7 of 7 (permalink) Old Feb 5th, 14, 09:52 PM Thread Starter
Thanks for the link Fred, I'll look into it. Meanwhile, here's some pics from tonight. I just picked up my freshly powder coated lowers with global west delalum bushings. I mocked them up with new spindles. I can't wait for the weekend so I am put back the front end and steering!
