control arms - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 9th, 14, 07:42 PM Thread Starter
camaro
control arms
Can control arms go bad???if so how do i detect if control arm is bad???they are all off the car
gm muscle 69 is offline
post #2 of 4 (permalink) Old Feb 9th, 14, 08:03 PM
Jerry
Re: control arms
Can they go bad? no. Can they be damaged? yes. Bushing and the like go bad. If you suspect the control arms are no longer good check for cracks, especially around welds.
69 SS/RS
565 BBC
Tremic 6 speed
Dragonfly Jones is offline
post #3 of 4 (permalink) Old Feb 10th, 14, 07:28 AM
David Pozzi
davidpozzi's Avatar
Re: control arms
The lower control arm carries a lot of load. Check the bent down flanges front & rear in the middle of the arm, the area in line with the spring seat.
davidpozzi is offline
post #4 of 4 (permalink) Old Feb 11th, 14, 12:16 PM
T.C.
Re: control arms
I've had Chevelle Lowers Break, so yes they can go Bad. Check Welds and the Area around the Ball Joint
T.C.
BMR SUSPENSION
My Camaro
Our 67-69 suspension on Two Guys Garage:
813-986-9302 Phone
TC
BMR Suspension is offline
