Another front spring question - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 15th, 14, 08:25 PM Thread Starter
I have spent a couple of hours trying to decide which front springs I need.
I am rebuilding the front suspension and want to replace the front coils while it's down. The car is a 68, 327 with intact factory air, was a factory auto car but has been converted to 4 speed.
I'd like to end up with a slightly firmer spring and near stock ride height.
I have searched these forums and read Pozzi's website and still don't have the answer. I looked at the thread where people were reporting their combinations, but didn't see any with stock subframe, stock control arms, AC, etc………I do plan to upgrade to 17" wheels and wider tires, but I'm not sure of sizes yet (could use some advide there too).
From what I can tell, I need something like a Moog 6308 or 6320 spring, but which one??
The Moog website is no help……same for the online parts places…….hoping someone here can steer me in the right direction.
GonHuntin is offline
post #2 of 7 (permalink) Old Feb 16th, 14, 02:03 AM
David Pozzi
davidpozzi's Avatar
Re: Another front spring question
I had 6308's on our 68 w factory air & it was nice. But we didn't have the compressor, condenser, or hoses. It did have the firewall "suitcase" & under-dash ducts/heater. We had stock A arms. Use of tubular A arms is going to affect height unpredictably.
Here it has 6308's with Hotchkis 1.5" drop leafs. We later added 1" lowering blocks.
davidpozzi is offline
post #3 of 7 (permalink) Old Feb 16th, 14, 04:24 AM
Frank
Here's a pic showing the stance of my 68 with a 327, no air, Richmond 5 speed, Hotchkis 1907F 2" drop front coil springs, and Hotchkis 1.5" drop rear leaf springs. Stock A-arms up front, urethane body mount bushings (Energy Suspension).
The wheels are 15 by 7 from a late 70s Chevy Caprice and all four tires are 215-70-15.
Frank350 is offline
post #4 of 7 (permalink) Old Feb 16th, 14, 04:35 AM Thread Starter
Thanks for the response.
I read about your combination but didn't know how much the weight of the AC compressor and condenser would change the situation??
Would the extra weight of the AC components be enough to make you move up to 6320 springs?
Assuming tires of similar diameter, would upgrading to wider 17" tires and wheels make a difference in your choice of springs? If so, where would the upgraded tires/wheels lead you??
I want to get this right the first time and I appreciate your advice.
Thanks, Mark
post #5 of 7 (permalink) Old Feb 16th, 14, 06:50 PM
David Pozzi
davidpozzi's Avatar
The 6308's are probably the best option. I think the compressor and condenser add around 40 lbs, and that would drop the front only .2" over what my 68 was.
If it came out too low for you, Global West sells metal shims you can slip under your coil springs.
Your camaro can ride nicely and handle well ( balanced oversteer/understeer) with this combo, but the front coils are too soft for serious autocrossing or driving to the max at the point of wheel lock up. I was pretty happy with the stock multi leaf springs originally on this car because it was a cruiser and didn't have much horsepower, plus auto tranny. We started with Hellwig sway bars front and rear with 6308's front, and stock multi leaf rear. Koni Shocks set fairly soft.
post #6 of 7 (permalink) Old Feb 17th, 14, 01:19 PM
T.C.
We will have Front Springs Soon!
T.C.
BMR Suspension is offline
post #7 of 7 (permalink) Old Feb 19th, 14, 12:49 PM Thread Starter
Thanks again David!
