tilt column - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 17th, 14, 12:04 AM Thread Starter
Ed
tilt column
Im planning to convert my 69 Z - straight column, manual steering box to a tilt column with a power steering box. I have purchased a power steering box - what else do I need to be aware of or buy besides a tilt column.
Appreciate your advise
Eddie M
69 Camaro Z/28
enio45 is offline
post #2 of 6 (permalink) Old Feb 17th, 14, 03:03 AM
jeff luzzi
Re: tilt column
Eddie, you need a power steering rag joint. It's different than the manual one. You can find nos on ebay from 150-200.
67ssrsl78conv is offline
post #3 of 6 (permalink) Old Feb 17th, 14, 06:46 AM
Robert
ROBS6T8's Avatar
Re: tilt column
Power steering pump and lines. Are you going with the IROC box?
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread
ROBS6T8 is offline
post #4 of 6 (permalink) Old Feb 17th, 14, 06:52 AM Thread Starter
Ed
Re: tilt column
no stock steering box
Eddie M
69 Camaro Z/28
enio45 is offline
post #5 of 6 (permalink) Old Feb 17th, 14, 08:13 AM
Jonesy's Avatar
Re: tilt column
The tilt column takes a different ignition switch than the non tilt column. So don't think you can use your switch on the column you are buying.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #6 of 6 (permalink) Old Feb 17th, 14, 08:26 AM
Dan
Re: tilt column
When i converted to tilt column guy at the junk yard told me a Buick Riveira would bolt in an sure enough it fit perfectly and there were twice as many Buicks in the yard compared to Camaro tilts. Just make sure its the same year.
realz69 is offline
