Lowering the rear in a 69. Question - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 19th, 14, 06:22 AM Thread Starter
I did a search but I didn't see what I was looking for. Before buying new leafs, I thought I'd ask how much lower would the rear be by removing 2 leafs from a 5 leaf spring? I have traction bars so I would figure 3 leafs and traction bars would stop wheel hop.
STM69 is offline
post #2 of 10 (permalink) Old Feb 19th, 14, 06:43 AM
Darin
ilikeike's Avatar
Re: Lowering the rear in a 69. Question
I would think it would be the thickness of the two springs,just like changing the thickness of a lowering block, and then any additional sag.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 10 (permalink) Old Feb 19th, 14, 06:54 AM
Rich
By removing the springs (leaving your clamps off) you can adjust the rear height and then clamp the leafs in that position. But be aware of where the rear shackles are so you don't cause damage to your inner rear and tail panel.
notatoy is offline
post #4 of 10 (permalink) Old Feb 19th, 14, 07:10 AM
DjD
DjD's Avatar
You add a block above the spring stack to lower the car. Removing springs from a spring stack has to come from below the top spring with the spring eye so the only change in height comes from changing the spring tension as you remove leafs from the stack.
...Dennis
DjD is offline
post #5 of 10 (permalink) Old Feb 19th, 14, 07:14 AM
Chad
cv2065's Avatar
You'll also possibly bottom out much easier. The correct method is de-arching or replacements. If you are only looking for an inch or less, I've used a 1" lowering block with good success.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #6 of 10 (permalink) Old Feb 19th, 14, 07:14 AM
DjD
DjD's Avatar
I don't believe the clamps or bands around a multi leaf spring stack have anything to do with holding the spring shape or spring tension. The bands just keep the leafs in the stack from twisting.
...Dennis
DjD is offline
post #7 of 10 (permalink) Old Feb 19th, 14, 07:22 AM
DjD
DjD's Avatar
This is too arbitrary of a question, how worn the springs are already, who makes the springs and what the initial spring tension of each leaf in the stack will have a factor in the final ride height.
As well changing the spring tension (sprung weight) by removing springs from the stack will effect the handling and ride quality.
...Dennis
DjD is offline
post #8 of 10 (permalink) Old Feb 19th, 14, 07:47 AM Thread Starter
Some generic Autozone 5 leaf replacements that were installed 10 years ago. Don't know the rates. On average.. is the cost of dearching them close to just buying the Hotchkis for $500?
STM69 is offline
post #9 of 10 (permalink) Old Feb 19th, 14, 08:22 AM Thread Starter
Or dearching prices versus Detroit Speeds $385 2" or 3" lowering springs?
STM69 is offline
post #10 of 10 (permalink) Old Feb 19th, 14, 03:50 PM
Try it. You're not out anything but a little time.
my 67' build thread:
allanjs is offline
