69 nova disc brakes to a 68 camaro? need help. - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 3rd, 03, 02:06 PM Thread Starter
I have a complete set up off a 69 nova, power booster, master cylinder, proportioning valve and spindles with all brakes parts. I know that the spindles are a bolt on. But what about the rest?
I am thinking of going manual brakes. Does anybody out there have a list of the part numbers for this swap or know what car thay come off of. Do I order all nova, or do I order 68 camaro parts? The 68 camaro I have is manual brakes with drums all the around.
Thanks, Pat
pgreen is offline
post #2 of 3 (permalink) Old Aug 3rd, 03, 03:12 PM
choptop's Avatar
Everything you have from the Nova will bolt right up! I would stick with the power brake setup since that is what you have on hand. When buying parts for the setup you can refer to it as '69 Camaro or Nova. Same either way! Just make sure you use the correct length pushrod from the brake pedal to the master cylinder- one is longer than the other!
choptop is offline
post #3 of 3 (permalink) Old Aug 3rd, 03, 03:54 PM Thread Starter
Thanks Scott For the info.
Pat
pgreen is offline
