jl8 brakes - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 23rd, 02, 04:49 PM Thread Starter
what is a set of complete jl8 rear disc brakes worth. Will they bolt up to a 12 bolt. Thanks
dipschmid is offline
post #2 of 7 (permalink) Old Jan 23rd, 02, 05:35 PM
Matt Jones
I believe the JL8 option was only available on Z/28's, which mandated the heavy duty (12-bolt) rear end.
As far as how much they are worth, it depends. One guy will pay alot more than the other. To give you an idea, a pair of reproduction JL8 caliper hose brackets will run you $125. An original JL8 setup is worth more than my engine alone, probably.
1969 Base Camaro
Vortec 350, TH-400
All sheetmetal is NOS GM
Silver69Camaro is offline
post #3 of 7 (permalink) Old Jan 23rd, 02, 05:49 PM
David Pozzi
davidpozzi's Avatar
While they are worth quite a bit. They are really just Corvette parts. The special 12 bolt housings had Vette bolt pattern brackets welded on where the backing plate brackets go.
A 12 bolt could be converted by cutting off the old bracket and welding on a hand made new one with correct pattern.
If you forgo the E-Brake, Guldstrand sells a flat 3/8" plate caliper bracket that bolts on.
The rotor drops on with no mods.
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer 65 Lola T-70 Chev 350 Can-Am Vintage Racer
davidpozzi is offline
post #4 of 7 (permalink) Old Jan 24th, 02, 02:45 PM Thread Starter
I bought those jl8 rear discs. They are in perfect shape right down to original brake shoes. When I went to try them on my 12 bolt they bolted right up. They have a small plate that fits over the axle housing and bolts right up to the existing mount. This steel plate has eight holes in it 4 to mount to the axle housing and 4 to bolt to the caliper mount. I have put the axle in and mounted the discs and caliper and everything lines up perfectly. I am getting all the parts bead blasted and powder coated(except the calipers). Does anyone know what colour they should be.
post #5 of 7 (permalink) Old Jan 25th, 02, 02:20 AM
I would recommend the Jerry McNeish book The Difinitave Camaro (Z-28) book. It has the complete part numbers and paint schemes and codes. We are nearly complete with a 69 Z-28
want to see some pics . . . . .
markZ11 is offline
post #6 of 7 (permalink) Old Jan 25th, 02, 04:37 AM
Red face
I priced a full JL8 rear end from Ricks and hold, brace yourself and sit down. $8,500 bucks. That was a year ago, so you might want to see if the price has dropped (ya right...chuckle).
Baby68RS is offline
post #7 of 7 (permalink) Old Jan 25th, 02, 09:01 AM
Jeff
Heartbeat city has a full set front and rear on their page right now for that nice low price of $8500.
Jeff 67/68 & 69 RS's
65 442
HawaiianCamaro is offline
