if I put on MOOG 6308??? - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 26th, 01, 04:42 PM Thread Starter
I have read so spring posts that I am beginning to forget what I have read. I have a 69 RS/SS with power disk brakes and A/C and I am getting ready to rebuild my front end while it is out of the car. I am going to go with the Performance Suspension polygraphite kit. 1" sway bar, and some new front coils. I would like to lower the front about an 1" or so. I read a post that said 6308s would lower it about this much and not have to worry about cutting coils. Has anybody else did this? What did it do? I considered Eibach but there has been more than a few posts that said they did not fit well. I would like to have a greater than factory spring rate(327?) but less than Hotchkis(and really dont want 2 " lower). Anybody have any ideas or thoughts or maybe a set of these springs or others that lower about that much and want to get rid of? I would like to put them in and be done with it. Not have to cut and fit to get them in the spring pockets. A mechanic I am not.
stacy is offline
post #2 of 4 (permalink) Old Nov 26th, 01, 09:57 PM
David Pozzi
davidpozzi's Avatar
Sounds good to me. With the air cond you have, I'm not sure the ride height will be high as you want.
You can shim them with a plastic coil spacer that is available, but it will make a jump in height due to the thickness of it.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 4 (permalink) Old Nov 27th, 01, 04:04 AM Thread Starter
Where do you get a spacer and where does it fit? Do you think it will lower it closer to 2" with the A/C? I forgot to note before that it has a 350 in it. What would Global West Springs do?
stacy is offline
post #4 of 4 (permalink) Old Nov 27th, 01, 06:07 AM
Cool
Remember that your front end is probably lower now than with brand new coils. I installed new Hotchkis springs and it looks about the same as before !
69 Camaro Z28 "clone" - 327 AT
"461" camel back heads,
edelbrock, hooker, ultradyne,
TRW etc.
700R4 TPI transmission
TJS69 is offline
