Who Has The Offset Rear Diff Problem??? - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 22nd, 02, 04:57 PM Thread Starter
I have read many posts lately concerning this "phenomenon" I figured maybe starting this post so that everybody can compare notes may lead to solving this mystery....
Maybe everybody can leave a little info regarding spring type.....high horsepower engine...stick or automatic....anything else that may help.....until I hear that somebody's 6cyl auto car is doing this I am still going with the "something in the chassis is twisting" theory...I don't think it's GM's stackup tolerances, since I havn't heard of anybody saying that there's is offset to the left.......Good Luck Guys...
18436527 is offline
post #2 of 13 (permalink) Old Feb 22nd, 02, 07:29 PM
Good idea.
'69 Camaro
It had a 350, 3 speed, single leaf, 10 bolt rearend. I didnt really look to see if things were shifter before I removed them. I only had the car a month before I started to tear it apart.
Completely gutted entire car, including engine subframe, and the entire rear suspension.
Replaced with Hotchkis drop springs and a new 12 bolt posi rearend....... its shifted about 3/4 inch to the pass side.
The sheetmetal is all original with only small areas of bondo, so its not a "bad bodywork" issue.
DRJDVM is offline
post #3 of 13 (permalink) Old Feb 22nd, 02, 08:32 PM
mine is shifted to the passenger's side slightly.. about 1/2-3/4''. My car is a 327 lo-po with TH350, 3.73 rear, multileaf conversion, traction bars...
boodlefoof is offline
post #4 of 13 (permalink) Old Feb 22nd, 02, 09:26 PM
i remember a thread a while back about the bushings in all the leaf springs being pushed all the way to one side- that would offset the rear end the same amount. the cure? press it so the leaf is at the inside of the bushing on both sides, thus centering it and gaining a touch of space for wider tires.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #5 of 13 (permalink) Old Feb 23rd, 02, 04:00 AM
msb
I have a 1980 229ci/auto. Just got it 2 weeks ago. All original except for the 200 has been swaped with a TH350, an 8-track and air shocks. The 8-track is gone, putting in a newer radio system today.
It doesn't look to have been wrecked, so things should still be lined up. I'll check the rear for shifting early next week at work and let you know.
The interior is ragged out, but other than that it's in pretty good shape. Fixing that and upgrading the suspension are my top priorities.
msb is offline
post #6 of 13 (permalink) Old Feb 23rd, 02, 04:14 AM
3/4" offset to right
68 RS 10-bolt 327 275hp powerglide
still offsetted with 3 leaf conversion
planning to offset all bushings to the right to compensate the axle offset.
[This message has been edited by MagnusRS68 (edited 02-23-2002).]
MagnusRS68 is offline
post #7 of 13 (permalink) Old Feb 23rd, 02, 05:11 AM
I've got a 67 that was originally a six cylinder and still has the original 10 bolt and original monoleafs. The car has had a 350/TH-350 in it for quite some time now. I have put Energy Suspension poly bushings in the rear. My rearend is perfectly centered in the car. I have evidence of body flexing elsewhere in the car - cracks at the A-pillars, sail panels, and the seam between the quarters and the panel behind the window, but the rearend has stayed centered in the car.
Justin Traunero
[email protected]
-1967 Camaro SS350 clone
My 1967 Camaro
jrt67ss350 is offline
post #8 of 13 (permalink) Old Feb 23rd, 02, 07:52 AM
Matt Jones
I think something else we need to post is what kind of bushings we are using (poly, rubber, solid), and is your driveshaft also offset in the tunnel? Or is it centered?
I'm gonna look at my Camaro and see if it's offset.
1969 Base Camaro
Vortec 350, Perf. RPM, Demon Carb., TH-400
All sheetmetal is NOS GM
http://www.geocities.com/compuboy007/
Silver69Camaro is offline
post #9 of 13 (permalink) Old Feb 23rd, 02, 09:25 AM
I had rubber before and now i have poly, and there was the same offset before and after. I beleive that it either something with the welded plates on the axletubes or the mountings front and rear.
Im going to check the driveshaft also and see if its centred or not.
post #10 of 13 (permalink) Old Feb 23rd, 02, 04:11 PM
Bruno
Mine is a 4 speed 68, originally V8. It has a 350 with a 12 bolts posi. Damn thing is also shifted to the right/passenger side 3/4". Haven't checked for the driveshaft yet.
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
ORENCH is offline
post #11 of 13 (permalink) Old Feb 24th, 02, 11:43 AM
I FIGURED OUT MY OFFSET PROBLEM !!!!!! Unfortunately it probably isnt the same problem you guys are having, sorry.
I jacked up the car and removed the rear wheels. After about 7-8 different measurements, I couldnt find anything off by more the 1/4 inch at best.
Then it dawned on me......... I'm using some temporary junk yard rims until I decide on my final rim/tire combo...... the rims look exactly the same, but I had always noticed the tires were different... no big deal, not that different..... but then I thought, what if the backspacing on the rims is different ?????
WHAAAAAAMMOOOO !!!!!! The rim I had on the drivers side has a 3/4 inch more backspacing !!!!!! Consequently the tire sits deeper in the wheelwell.
I'm so glad I figured it out. This has been driving me crazy for the last 3 weeks !!!
I guess the old KISS rule applies here (Keep It Simple Stupid !!!) Look for the simple things first.
This probably wont help many of you, but it wouldnt hurt to be absolutley sure its not something stupid like my issue. Check the backspacing to be sure. It couldnt hurt to absolutely rule that out. Maybe those rims you bought are really different ??? Its an easy detail to not really look at. You just assume they are the same on each side....
Its is kind of wierd that everyone is shifted to the pass side ???? Wierd....
Good luck everyone...
DRJDVM is offline
post #12 of 13 (permalink) Old Feb 24th, 02, 12:03 PM
Glad you solved your shifted rear/wheel =)
I looked at my backside setting on my wheels the first thing i did, and they are new aswell.
First i thougt that maybe/hopefully the former owner had a spacer or something, but when i changed to my new wheels i realized that its more complicated. =(
post #13 of 13 (permalink) Old Feb 24th, 02, 12:13 PM
Bruno
I don't have too wide tires so as long as it doesn't interfere with hard launches, I don't care that much. Maybe doing so it gets to where it belongs. Just hope the 12 bolts resist the abuse. Like some say, Drive it like you stole it...
ORENCH is offline
