Cut coils = front end alignment? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 28th, 01, 03:50 AM Thread Starter
john
If I replace the front springs or cut off a coil to lower my car will my front end alignment change? If so, what will be affected... caster, camber...? Thanks.
john
70 Nova
fujimook is offline
post #2 of 3 (permalink) Old Sep 28th, 01, 04:05 AM
Caster and S.A.I. will be the most effected. Any time you change the cars highth you are changing alignment, I have seen some who changed tires and needed one. What happens is the angle of load changes. It is like a bicycle or shoping cart, if you look at one you will see that the angle of the tire is behind the load. (on a bicycle draw a line from the center of the handlebars down through the axle of the front wheel) That is why you were able to go "look ma, no hands!" when you change this angle you get either real hard turning or a car that "wanders" on the road. (not good at 4 in the morning when all the cops are out!) My personal thought is to use lowering shackles or sport springs instead of cutting, then go get an alignment.
78 Camaro LT is offline
post #3 of 3 (permalink) Old Sep 29th, 01, 02:32 PM
Joe
When you lower a car you change all the alignment angles. Camber changes the most then toe and caster will change very little if at all. Thats why all those lowered hondas wear tires real bad, they have no adjustment for camber.
If you do lower the car I suggest that you install lowered shocks and spindles too. The car will ride like crap and will not align right without them.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
