Pitman Shaft Nut - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 16th, 01, 02:12 PM Thread Starter
Apprentice
Matt
Send a message via AIM to MTidwell Send a message via MSN to MTidwell
Need help in removing this 1 1/2" Nut from the steering shaft. This bad boy won't come off and has probably not been removed since 1968. Thought about applying heat to the nut but do not want to do any damage to the seals on the steering box. Any suggestions.
68 Camaro Convertible, 350SB,5spd,9"
MTidwell is offline
post #2 of 6 (permalink) Old Oct 16th, 01, 02:48 PM
David Pozzi
davidpozzi's Avatar
That's because the factory torque spec for it is 140 LBS!!
It's no wonder you are having trouble.
A good impact gun is what you need.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 6 (permalink) Old Oct 17th, 01, 04:34 AM
Guess
HwyStarJoe's Avatar
If ya can't get someone with an impact wrench to help you, try a long breaker bar on the handle of your ratchet or socket wrench. I couldn't live without 'em! Just go slow and gradually apply pressure until it starts to turn.
Good luck!
HwyStarJoe is offline
post #4 of 6 (permalink) Old Oct 18th, 01, 08:47 AM
I keep an old laccrosse shaft behind my toolbox for this purpose. It can slip over my 3/8 or 1/2 inch ratchet
Big breaker bar is the way to go though
68ragtop is offline
post #5 of 6 (permalink) Old Oct 18th, 01, 10:44 AM
Rick
I had to use a breaker bar and a 3' pipe. Started to wonder if magnetic North was going to shift!
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips.
RickD is offline
post #6 of 6 (permalink) Old Oct 18th, 01, 02:30 PM Thread Starter
Apprentice
Matt
Talking
Thanks for the suggestions. Was able to muscle it off and replace a badly worn part.
MTidwell is offline
